[Qgis-user] exporting data
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Tue Jun 16 07:20:37 PDT 2020
I used qpackage for that. I imagine it’s also made for QGIS 3x.
https://gis.stackexchange.com/questions/33327/is-there-an-automatic-function-in-qgis-to-package-all-files-in-a-project-for-tra
If you have all your files in the same folder structure, you can also just send the folder. That is not always possible because it can lead to the multiplication of identical files but if I know I will export something, that is usually the way to go.
You can have multiple sub folders in the folder structure. QGIS normally uses relative paths so the project will be able to find the files.
Nicolas Cadieux
Ça va bien aller!
> Le 16 juin 2020 à 08:59, Boaz Bar Ilan <boazprosie at gmail.com> a écrit :
> hi everyone
> i need to send work which i did to another gis system
> what is the best way to do it and how
> i tried export shapefile but it dont keep the definitions
> i tried save as layer definition file and it doesnt work
> i tried save feature as geopackage and it didnt work
> can someone help in this ?
> thanks
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200616/54647c7c/attachment.html>
