[Qgis-user] How to determine the inner surface on a sphere or ellipsoid
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Tue Jun 16 07:56:40 PDT 2020
To my knowledge no.  The second option would be a polygone that covers the earth but that has a hole in it.  That is the Generally accepted topology in GIS.
Nicolas Cadieux
Ça va bien aller!
> Le 16 juin 2020 à 10:28, Tudorache, Marian <Marian.Tudorache at navcanada.ca> a écrit :
> Hi everyone,
> I have a list of polygons given by a list of points.
> The polygons are properly drawn on QGIS canvas by creating the geometries, the each geometry is used to create a Qgsfeature which are saved on a shapefile.
> The problem appears in detecting if a point on the Earth is inside or outside the polygon.
> Using pyqgis QgsGeometry intersects function returns proper value.
> However when I export the polygon to intermaphics from Kongsberg Geospatial (former Gallium) sometime the point is inside other time is outside the polygon.
> I tried to switch the order of the points is QGIS ,but the intersects function always give me the same result regardless of the order of the points.
> In intermaphics the intersection between a polygon and a point varies with the order of the points which define a polygon.
> I talked to people from gallium and they confirmed the order of the points is important.
> In one direction a inner area of the polygon is the small surface and if I switch the order the inner area is the outside and it wraps the Earth on the opposite side.
> Does QGIS or pyqgis has a similar mechanism to determine which is the inner part of the polygon on a sphere or ellipsoid?
> Thanks,
> Marian
> ________________________________
> This electronic message, as well as any transmitted files included in the electronic message, may contain privileged or confidential information and is intended solely for the use of the individual(s) or entity to which it is addressed. If you have received this electronic message in error please notify the sender immediately and delete the electronic message. Any unauthorized copying, disclosure or distribution of the electronic message is strictly forbidden. NAV CANADA accepts no liability for any damage caused by any virus and/or other malicious code transmitted by this electronic communication.
> Le présent message électronique et tout fichier qui peut y être joint peuvent contenir des renseignements privilégiés ou confidentiels destinés à l’usage exclusif des personnes ou des organismes à qui ils s’adressent. Si vous avez reçu ce message électronique par erreur, veuillez en informer l’expéditeur immédiatement et supprimez le. Toute reproduction, divulgation ou distribution du prése
