[Qgis-user] Update field based on a value from another layer
Tony Shepherd (FarmMaps NZ) tony at farmmaps.nz
Tue Jun 23 20:29:58 PDT 2020
Hi All
Am I missing something?  Is there a simple point and click tool in QGIS to
update an existing field in a QGIS layer based on a value in another using a
geographic join?  For example a series of points and a series polygons.  I
want to update a field in points from a value in a field in polygons based
on which polygon the point falls in.  Simple stuff.
In a previous life using MapInfo we simply used query editor and
update point_layer set col1 = colx from polygon_layer where obj within any
To me, this seems like a very simple everyday thing to do to an existing
table.  I can, of course, use vector -> Join Attributes by Column but why in
this case would I needlessly complicate things by having to create a third
layer?  I don't need an extra layer, I just need to update the one I have
already.
I can see that the internet is littered with similar questions dating back
as long as QGIS has been around.  Perhaps I have missed something obvious,
and if so apologies for wasting the time of others, but can you point me to
the tool?
Cheers
Tony
Tony Shepherd  |  GeoSpatial / Mapping Manager
Ph 027 435 6193  |  E  <mailto:tony at farmmaps.nz> tony at farmmaps.nz
FarmMaps NZ, 3 Kerwood Place, Gore 9740
 <http://tonyshepherd8.wixsite.com/home>
<https://www.wunderground.com/personal-weather-station/dashboard?ID=ISTLGORE
2>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200624/c47076af/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200624/c47076af/attachment.jpg>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200624/c47076af/attachment.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200624/c47076af/attachment-0001.png>
