[Qgis-user] CRS Errors
Stewart Holt
stewartbholt at gmail.com
Wed Mar 11 08:11:42 PDT 2020
Yes, I have also noticed this. I think it started in some point rev of
3.10.x. I still see it in 3.12. Most of my work is using a WMS layer with
EPSG:3857. The ellipsoidal calculation would need to start with coordinates
in degrees and I wonder if it is passing the rectangular coordinates. I
think this either used to work or the default measurement used to be
cartesian and I never tried ellipsoidal because I am usually concerned with
distances of a few meters.
Stewart
On Wed, Mar 11, 2020 at 9:17 AM Tyler Veinot <tylerkveinot at gmail.com> wrote:
> Has anyone had this issue?
> My measurements when using the ellipsoidal measur are in the millions of
> meters for things that are only a few hundred or less meters long. It isn't
> a unit issue because I tried dividing for cm, mm, dm and the
> measurements don't add up. If I go to cartesian the measurements look fine.
> Before this was happening my QGIS was also assigning epsg 2292 to my
> shapfiles having an epsg of 2954. I check the file geodatabase they were
> exported from and the proj files and they all reference EPSG 2954 and not
> EPSG 2292. Also All new projects are defaulted to 2954 so no
> transformations should be necessary.
> Since updating to QGIS3 I noticed this transformation section in the
> settings under CRS, is there something here I inadvertently changed?
> I do have my own GSB files for coordinate transformations from survey
> grids but I have not figured out how to employ them yet in QGIS3 so I don't
> think they would be an issue.
> Anyone else have a similar thing start to happen?
> Thanks;
> Tyler
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200311/81e75609/attachment.html>
