[Qgis-user] OpenLayersPlugin
Tim Smith
tim.smith at fivevalleysecology.co.uk
Fri Mar 20 11:21:35 PDT 2020
Hi All
I am using QGIS 2.18.17 on Linux Mint 19.3. What I need to do is
display a Google or other aerial image such as Bing on my map. So, I
am trying to install OpenLayers Plugin but keep getting an error saying
'The plugin is broken. Python said cannot import name QtWebKit'. I
also get the following:
> p, li { white-space: pre-wrap; }
> Couldn't load plugin openlayers_plugin due to an error when calling
> its classFactory() method
> ImportError: cannot import name QtWebKit
> Traceback (most recent call last):
> File "/usr/lib/python2.7/dist-packages/qgis/utils.py", line 333, in
> startPlugin
> plugins[packageName] = package.classFactory(iface)
> File
> "/home/tim/.qgis2/python/plugins/openlayers_plugin/__init__.py", line
> 25, in classFactory
> from openlayers_plugin import OpenlayersPlugin
> File "/usr/lib/python2.7/dist-packages/qgis/utils.py", line 607, in
> _import
> mod = _builtin_import(name, globals, locals, fromlist, level)
> File
> "/home/tim/.qgis2/python/plugins/openlayers_plugin/openlayers_plugin.
> py", line 30, in
> from openlayers_overview import OLOverview
> _import
> File
> "/home/tim/.qgis2/python/plugins/openlayers_plugin/openlayers_overvie
> w.py", line 23, in
> from openlayers_ovwidget import OpenLayersOverviewWidget
> _import
> File
> "/home/tim/.qgis2/python/plugins/openlayers_plugin/openlayers_ovwidge
> t.py", line 38, in
> from ui_openlayers_ovwidget import Ui_Form
> _import
> File
> "/home/tim/.qgis2/python/plugins/openlayers_plugin/ui_openlayers_ovwi
> dget.py", line 80, in
> from PyQt4 import QtWebKit
> Python version: 2.7.17 (default, Nov 7 2019, 10:07:09) [GCC 7.4.0]
> QGIS version: 2.18.17 Las Palmas, exported
> Python Path:
> /usr/share/qgis/python/plugins/processing
> /usr/lib/python2.7
> /usr/lib/python2.7/plat-x86_64-linux-gnu
> /usr/lib/python2.7/lib-tk
> /usr/lib/python2.7/lib-old
> /usr/lib/python2.7/lib-dynload
> /usr/local/lib/python2.7/dist-packages
> /usr/lib/python2.7/dist-packages/gtk-2.0
> /home/tim/.qgis2//python
> /home/tim/.qgis2/python/plugins/go2streetview
I get a similar error when I try to load other plugins such as
gotostreetview. Please could anybody advise how I can get the plugin
working so I can use an aerial image on my map, thank you?
Kind Regards
Tim
Tim Smith BSc (Hons) MCIEEM
Managing Director and Principal Ecologist
Informing - Reducing Risk - Adding Value
www.fivevalleysecology.co.uk
T: +44 (0)1453 759306 – Choose Option 1
M: +44 (0)7732 397984
5 St Brendans Road
Stroud
Gloucestershire
GL5 1PB
CIEEM Member Subject to Code of Professional Conduct
Registered in England No. 7540564
VAT No. 133 4074 43
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this email. Please notify Five Valleys Ecology Ltd immediately by email if you have received this email by mistake and delete this email from your system. If you are not the intended recipient you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
We have checked this email and its attachments for viruses. The recipient should also check this email and any attachments for the presence of viruses. Five Valleys Ecology Ltd accepts no liability for any damage caused by any virus transmitted by this email.
Please consider the environment before printing this email
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200320/7926a95c/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200320/7926a95c/attachment-0001.png>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200320/7926a95c/attachment-0002.jpg>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200320/7926a95c/attachment-0003.jpg>
