[Qgis-user] Select features inconsistency on QGIS 2.18
Tudorache, Marian
Marian.Tudorache at navcanada.ca
Fri Mar 27 10:27:43 PDT 2020
Hi everyone,
I have found an inconsistency on the way how select features works in QGIS 2.18.
If I use actionSelectRectangle or actionSelect the selection disappears when I hold Shift + left mouse key.
This does not happen if I use actionSelectFreehand, actionSelectPolygon or actionSelectRadius.
I try to find in user manual the difference the behavior differences and I found nothing.
Normally when I want to do multi features selection I use either Ctrl + left mouse key click or Shift + left mouse key click and drag.
If actionSelectRectangle or actionSelect is used I have to be fast because if I hold too long (3 secodns) the two keys (Shift and left mouse key) the entirely previous selectin is lost.
Thank you,
Marian
This electronic message, as well as any transmitted files included in the electronic message, may contain privileged or confidential information and is intended solely for the use of the individual(s) or entity to which it is addressed. If you have received this electronic message in error please notify the sender immediately and delete the electronic message. Any unauthorized copying, disclosure or distribution of the electronic message is strictly forbidden. NAV CANADA accepts no liability for any damage caused by any virus and/or other malicious code transmitted by this electronic communication.
Le pr?sent message ?lectronique et tout fichier qui peut y ?tre joint peuvent contenir des renseignements privil?gi?s ou confidentiels destin?s ? l'usage exclusif des personnes ou des organismes ? qui ils s'adressent. Si vous avez re?u ce message ?lectronique par erreur, veuillez en informer l'exp?diteur imm?diatement et supprimez le. Toute reproduction, divulgation ou distribution du pr?sent message ?lectronique est strictement interdite. NAV CANADA n'assume aucune responsabilit? en cas de dommage caus? par tout virus ou autre programme malveillant transmis par ce message ?lectronique.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200327/34553251/attachment.html>
