[Qgis-user] Refresh layer at interval
nagyrobi_r at yahoo.com
Sun Nov 1 12:24:46 PST 2020
Hi All!
I am trying to understand the behavior of Layer->Render-> Refresh layer at interval in QGIS
- I sat up a flask rest api which serves a geojson.
- I added the geojson to QGIS via Add Layer->
- a. Protocol HTTP/cloud/etc
- b. Type: HTTP
- c.URI: localhost/points.geojson The points are represented on the map correctly
- I changed the layer->Properties->Rendering-> Refresh layer at interval (5 sec)
I would have expected that there would be a call every 5 seconds towards the server and the map data would be updated accordingly. But the layer does not get refreshed. I don't see any changes neither when I remove a point from the json file on my local drive, nor if I change an attribute. If I press F5 then the canvas refreshes and it automatically loads the new data and I can see the changes. Is this the behavior that is wanted or am I misunderstanding the function of this tool? It seems like the data is cached somewhere?
from flask import Flask
from flask_restful import Api, Resource
import json
app = Flask(__name__)
api = Api(app)
class point(Resource):
def get(self):
with open('C:/points/venv/src/points.geojson') as json_file:
data = json.load(json_file)
return data
api.add_resource(point,"/points.geojson")
if __name__=="__main__":
app.run(debug=True)Robert Nagy
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201101/55011caf/attachment.html>
