[Qgis-user] Colorized Area by Sensorpointdata
Stefan Giese
Stefan.Giese at wheregroup.com
Mon Nov 9 00:24:07 PST 2020
Hi Michi,
welcome to the QGIS community. I would suggest to start wirth some
basics like howto interpolate rasters from points. There is a good Video
from Hans van der Kwast: https://www.youtube.com/watch?v=By-K5C7jDQc
or you can start with the QGIS Documentation:
https://docs.qgis.org/3.10/en/docs/gentle_gis_introduction/spatial_analysis_interpolation.html
hope this helps
Stefan
Mit freundlichen GrüÃen
Stefan Giese
Projektleiter/Consultant
Aufwind durch Wissen!
Jetzt neu: Web-Seminare und Online-Schulungen
bei der www.foss-academy.com
WhereGroup GmbH
Schwimmbadstr. 2
79100 Freiburg
Germany
Fon: +49 (0)761 / 519 102 - 61
Fax: +49 (0)761 / 519 102 - 11
stefan.giese at wheregroup.com
www.wheregroup.com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
Am 09.11.2020 um 09:10 schrieb Michael Rest:
> Hello,
> I'm new to QGIS. I have a file with Measurement Values (Latitude,
> Longitude, Measeurement Values),
> and want to visualize this values with colored areas (like in the
> attached Screenshot or like a temperature graduation ),
> due to the fact that the values are point values the values shoult be
> interpolated to the next values.
> I found QGIS and i guess this is the right tool.
> I already managed to import the Values as a dedicated text layer and
> colorize the Points. I also found the heatmap fuction (and the
> temperature tutorial), but Im not sure if this is the correct way. As
> far as i see the heatmap is for highlighting Areas with higher density
> points (even if i use weight by ma measurement value), which is not
> what i really want.
> I hope i explained my issue enough (i also tried searching the 2020
> Archives of the Mailinglist threads without success),
> and somebody has a tipp or a solution for me.
> Best regards
> Michi
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201109/e244d748/attachment.html>
Type: application/pgp-keys
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201109/e244d748/attachment.key>
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201109/e244d748/attachment.sig>
