[Qgis-user] Keeping layers of an imported DXF file into QGIS
Nicolas Cadieux
njacadieux.gitlab at gmail.com
Mon Nov 9 08:12:41 PST 2020
I will set others respond as I am currently updating my laptop to Linux. I only expect to have a working version of QGIS later today.
Being a spelunker in Montreal, I would like to volunteer for futur mapping project. Contact me directly if you need help.
Nicolas Cadieux
> Le 9 nov. 2020 à 10:33, Luc Le Blanc <speleoluc at gmail.com> a écrit :
> DXF file shared.
> I'm forwarding answers to my user.
>> Le lun. 9 nov. 2020 à 10:25, Andreas Neumann <andreas at qgis.org> a écrit :
>> Hi Luc,
>> Can you share such a dxf with me?
>> As just written in my other mail (seconds ago), please also try the native way of importing the DXF to a Geopackage through menu "Project --> Import/Export --> Import Layers from DWG/DXF"
>> Andreas
>>> On Mon, 9 Nov 2020 at 16:03, Luc Le Blanc <speleoluc at gmail.com> wrote:
>>> That's our impression too, as QGIS ends up with (3) layers of shapes,
>>> lines and text. The problem is that this line layer is a bulk merge of
>>> several DXF layers representing different things (line plot, passage
>>> widths, walls, etc.) that the user would like to toggle (hide/show) or
>>> even exclude from the import. Just knowing the layer of origin is not
>>> sufficient. Can QGIS act upon these attributes other than just showing
>>> them? (I'm not a QGIS user, just researching for an Auriga user who
>>> asked me).
>>> Le lun. 9 nov. 2020 à 09:43, Charles Dixon-Paver <charles at kartoza.com> a écrit :
>>>> I think the DXF is just split by geometry type, but you should be able to access the "layer" information via the attributes.
>>>> On Mon, 9 Nov 2020 at 16:24, Luc Le Blanc <speleoluc at gmail.com> wrote:
>>>>> Hi,
>>>>> My cave survey freeware exports DXF files organized in multiple layers
>>>>> for survey stations, station names, line plot, wall lines, etc.
>>>>> A user tells me that when he imports this DXF into QGIS, everything
>>>>> gets merged into 3 layers containing station markers (small
>>>>> triangles). lines (line plot, passage widths, walls, altogether) and
>>>>> station names.
>>>>> Is it possible for QGIS to neatly import a layered DXF file into
>>>>> corresponding layers, respecting the initial organization?
>>>>> Luc Le Blanc
>>>>> http://www.speleo.qc.ca/Auriga
>>>>> _______________________________________________
>>>>> Qgis-user mailing list
>>>>> Qgis-user at lists.osgeo.org
>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Luc Le Blanc
>> Andreas Neumann
>> QGIS.ORG board member (treasurer)
> Luc Le Blanc
