[Qgis-user] Qgis startup crashes on Debian 10
Patrick Dunford
enzedrailmaps at gmail.com
Fri Nov 13 01:34:38 PST 2020
Again as we saw with builds earlier this year, the latest 3.10.11 build
will crash on startup. This happens on anything I can find running
Debian 10.
There aren't seen anything similar on Ubuntu.
Is there likely to be some sort of issue with the build environment that
affects Debian 10 compatibility?
The below is a K crash dump.
Application: qgis (qgis), signal: Segmentation fault
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
[Current thread is 1 (Thread 0x7feb14a2ce40 (LWP 11173))]
Thread 8 (Thread 0x7feafc8bd700 (LWP 11185)):
#0Â 0x00007feb1d38f3f9 in pthread_cond_timedwait@@GLIBC_2.3.2 () from
/lib/x86_64-linux-gnu/libpthread.so.0
#1Â 0x00007feb1d9490fc in QWaitCondition::wait(QMutex*, unsigned long)
() from /lib/x86_64-linux-gnu/libQt5Core.so.5
#2Â 0x00007feb1d9411f2 in ?? () from /lib/x86_64-linux-gnu/libQt5Core.so.5
#3Â 0x00007feb1d948a67 in ?? () from /lib/x86_64-linux-gnu/libQt5Core.so.5
#4Â 0x00007feb1d388fa3 in start_thread () from
#5Â 0x00007feb1d49d4cf in clone () from /lib/x86_64-linux-gnu/libc.so.6
Thread 7 (Thread 0x7feafd0be700 (LWP 11184)):
[KCrash Handler]
#6Â 0x00007feb1df11b84 in ?? () from
/lib/x86_64-linux-gnu/libQt5Network.so.5
#7Â 0x00007feb1df10c49 in ?? () from
#8Â 0x00007feb1db1a072 in QObject::event(QEvent*) () from
#9Â 0x00007feb20c2d4c1 in QApplicationPrivate::notify_helper(QObject*,
QEvent*) () from /lib/x86_64-linux-gnu/libQt5Widgets.so.5
#10 0x00007feb20c34970 in QApplication::notify(QObject*, QEvent*) ()
#11 0x00007feb246c680b in QgsApplication::notify(QObject*, QEvent*) ()
from /lib/libqgis_core.so.3.10.11
#12 0x00007feb1daf0489 in QCoreApplication::notifyInternal2(QObject*,
QEvent*) () from /lib/x86_64-linux-gnu/libQt5Core.so.5
#13 0x00007feb1daf346b in
QCoreApplicationPrivate::sendPostedEvents(QObject*, int, QThreadData*)
#14 0x00007feb1db42103 in ?? () from /lib/x86_64-linux-gnu/libQt5Core.so.5
#15 0x00007feb1bbc0f2e in g_main_context_dispatch () from
/lib/x86_64-linux-gnu/libglib-2.0.so.0
#16 0x00007feb1bbc11c8 in ?? () from /lib/x86_64-linux-gnu/libglib-2.0.so.0
#17 0x00007feb1bbc125c in g_main_context_iteration () from
#18 0x00007feb1db41727 in
QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>)
#19 0x00007feb1daef15b in
QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) () from
#20 0x00007feb1d93ee76 in QThread::exec() () from
#21 0x00007feb1d948a67 in ?? () from /lib/x86_64-linux-gnu/libQt5Core.so.5
#22 0x00007feb1d388fa3 in start_thread () from
#23 0x00007feb1d49d4cf in clone () from /lib/x86_64-linux-gnu/libc.so.6
Thread 6 (Thread 0x7feafd8bf700 (LWP 11183)):
#0Â 0x00007feb1d492819 in poll () from /lib/x86_64-linux-gnu/libc.so.6
#1Â 0x00007feb1bbc1136 in ?? () from /lib/x86_64-linux-gnu/libglib-2.0.so.0
#2Â 0x00007feb1bbc125c in g_main_context_iteration () from
#3Â 0x00007feb1db41743 in
#4Â 0x00007feb1daef15b in
#5Â 0x00007feb2488e3d0 in QgsNetworkContentFetcherTask::run() () from
#6Â 0x00007feb2499a262 in QgsTask::start() () from
#7Â 0x00007feb1d940fe1 in ?? () from /lib/x86_64-linux-gnu/libQt5Core.so.5
#8Â 0x00007feb1d948a67 in ?? () from /lib/x86_64-linux-gnu/libQt5Core.so.5
#9Â 0x00007feb1d388fa3 in start_thread () from
#10 0x00007feb1d49d4cf in clone () from /lib/x86_64-linux-gnu/libc.so.6
Thread 5 (Thread 0x7feafe15f700 (LWP 11182)):
#0Â 0x00007feb1d48e537 in write () from /lib/x86_64-linux-gnu/libc.so.6
#1Â 0x00007feb1bc06b5a in ?? () from /lib/x86_64-linux-gnu/libglib-2.0.so.0
#2Â 0x00007feb1daf39b5 in QCoreApplication::postEvent(QObject*, QEvent*,
int) () from /lib/x86_64-linux-gnu/libQt5Core.so.5
#3Â 0x00007feb1db1954a in QMetaObject::activate(QObject*, int, int,
void**) () from /lib/x86_64-linux-gnu/libQt5Core.so.5
#4Â 0x00007feb1df37c64 in
QNetworkConfigurationManagerPrivate::updateConfigurations() () from
#5Â 0x00007feb1dfc470d in ?? () from
#6Â 0x00007feb1db1a072 in QObject::event(QEvent*) () from
#7Â 0x00007feb1daf0466 in QCoreApplication::notifyInternal2(QObject*,
#8Â 0x00007feb1daf346b in
#9Â 0x00007feb1db42103 in ?? () from /lib/x86_64-linux-gnu/libQt5Core.so.5
#10 0x00007feb1bbc0f2e in g_main_context_dispatch () from
#11 0x00007feb1bbc11c8 in ?? () from /lib/x86_64-linux-gnu/libglib-2.0.so.0
#12 0x00007feb1bbc125c in g_main_context_iteration () from
#13 0x00007feb1db41727 in
#14 0x00007feb1daef15b in
#15 0x00007feb1d93ee76 in QThread::exec() () from
#16 0x00007feb1d948a67 in ?? () from /lib/x86_64-linux-gnu/libQt5Core.so.5
#17 0x00007feb1d388fa3 in start_thread () from
#18 0x00007feb1d49d4cf in clone () from /lib/x86_64-linux-gnu/libc.so.6
Thread 4 (Thread 0x7feafe975700 (LWP 11181)):
#5Â 0x00007feb2086b0d1 in QCA::SyncThread::run() () from
/lib/x86_64-linux-gnu/libqca-qt5.so.2
#6Â 0x00007feb1d948a67 in ?? () from /lib/x86_64-linux-gnu/libQt5Core.so.5
#7Â 0x00007feb1d388fa3 in start_thread () from
#8Â 0x00007feb1d49d4cf in clone () from /lib/x86_64-linux-gnu/libc.so.6
Thread 3 (Thread 0x7feb0bfff700 (LWP 11179)):
#0Â 0x00007feb1d48e494 in read () from /lib/x86_64-linux-gnu/libc.so.6
#1Â 0x00007feb1bc06aa0 in ?? () from /lib/x86_64-linux-gnu/libglib-2.0.so.0
#2Â 0x00007feb1bbc0c0f in g_main_context_check () from
#3Â 0x00007feb1bbc10e0 in ?? () from /lib/x86_64-linux-gnu/libglib-2.0.so.0
#4Â 0x00007feb1bbc125c in g_main_context_iteration () from
#5Â 0x00007feb1db41743 in
#6Â 0x00007feb1daef15b in
#7Â 0x00007feb1d93ee76 in QThread::exec() () from
#8Â 0x00007feb266cd545 in ?? () from /lib/x86_64-linux-gnu/libQt5DBus.so.5
#9Â 0x00007feb1d948a67 in ?? () from /lib/x86_64-linux-gnu/libQt5Core.so.5
#10 0x00007feb1d388fa3 in start_thread () from
#11 0x00007feb1d49d4cf in clone () from /lib/x86_64-linux-gnu/libc.so.6
Thread 2 (Thread 0x7feb14a14700 (LWP 11177)):
#0Â 0x00007feb1d38f00c in pthread_cond_wait@@GLIBC_2.3.2 () from
#1Â 0x00007feb1d7b83bc in
std::condition_variable::wait(std::unique_lock<std::mutex>&) () from
/lib/x86_64-linux-gnu/libstdc++.so.6
#2Â 0x00007feb23483542 in ?? () from /lib/x86_64-linux-gnu/libQt5WebKit.so.5
#3Â 0x00007feb23483659 in ?? () from /lib/x86_64-linux-gnu/libQt5WebKit.so.5
#4Â 0x00007feb1d7bdb2f in ?? () from /lib/x86_64-linux-gnu/libstdc++.so.6
#5Â 0x00007feb1d388fa3 in start_thread () from
#6Â 0x00007feb1d49d4cf in clone () from /lib/x86_64-linux-gnu/libc.so.6
Thread 1 (Thread 0x7feb14a2ce40 (LWP 11173)):
#3Â 0x00007feb20c6d09a in QWidgetPrivate::init(QWidget*,
QFlags<Qt::WindowType>) () from /lib/x86_64-linux-gnu/libQt5Widgets.so.5
#4Â 0x00007feb20d13c0b in
QAbstractButton::QAbstractButton(QAbstractButtonPrivate&, QWidget*) ()
#5Â 0x00007feb20dfc950 in QToolButton::QToolButton(QWidget*) () from
#6Â 0x00007feb20df1413 in ?? () from
#7Â 0x00007feb20df1591 in ?? () from
#8Â 0x00007feb20c6b4d8 in QWidget::event(QEvent*) () from
#9Â 0x00007feb20df091b in QToolBar::event(QEvent*) () from
#10 0x00007feb20c2d4c1 in QApplicationPrivate::notify_helper(QObject*,
#11 0x00007feb20c34970 in QApplication::notify(QObject*, QEvent*) ()
#12 0x00007feb246c680b in QgsApplication::notify(QObject*, QEvent*) ()
#13 0x00007feb1daf0489 in QCoreApplication::notifyInternal2(QObject*,
#14 0x00007feb20c62877 in QWidget::insertAction(QAction*, QAction*) ()
#15 0x00007feb26dacd22 in ?? () from /lib/libqgis_gui.so.3.10.11
#16 0x00007feb26da80a1 in
QgsBrowserDockWidget::QgsBrowserDockWidget(QString const&,
QgsBrowserGuiModel*, QWidget*) () from /lib/libqgis_gui.so.3.10.11
#17 0x00007feb2762a435 in QgisApp::QgisApp(QSplashScreen*, bool, bool,
QString const&, QString const&, QWidget*, QFlags<Qt::WindowType>) ()
from /lib/libqgis_app.so.3.10.11
#18 0x000055d6199d05c4 in ?? ()
#19 0x00007feb1d3c809b in __libc_start_main () from
#20 0x000055d6199d395a in _start ()
[Inferior 1 (process 11173) detached]
