[Qgis-user] Dynamic Line
Andreas Neumann
a.neumann at carto.net
Fri Nov 13 02:33:03 PST 2020
Yes - you can use Geometry Generators for that. Use the make_point() and
make_line() expressions for that.
See
https://docs.qgis.org/3.10/en/docs/user_manual/style_library/symbol_selector.html?highlight=geometry%20generator#the-geometry-generator
Greetings,
Andreas
Am 13.11.20 um 11:26 schrieb L.W.:
> Hi,
> is it possible to draw automatically a line between two points defined
> by 4 fields (x1,y1 - x2,y2) in an attributetable?
> but I do not want to add a line-layer based on this table nor want to
> draw the line by hand.
> thanks
> Qgis-user mailing list
