[Qgis-user] Update second table
L.W.
eaglelw at gmx.de
Fri Nov 13 08:34:37 PST 2020
they are not in the same database at the same datebase-server :-(
i forgot to tell ...
Am 13.11.2020 um 17:02 schrieb chris hermansen:
> L.W. and list
> On Fri, Nov 13, 2020, 06:39 L.W. <eaglelw at gmx.de
> <mailto:eaglelw at gmx.de>> wrote:
> hi,
> can I update a second table autom. if the value of first table
> changes?
> This is pretty easy if the tables are in a relational database. You
> use a thing called a trigger, perhaps together with a stored procedure.
> It seems that SQLite has triggers so I imagine you can do this within
> a geopackage. Certainly if your data is in PostGIS / PostgreSQL.
> Chris
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201113/7116ce04/attachment.html>
