[Qgis-user] TOGGLE EDIT ( ✏️) BUTTON NOT WORKING ( GREY)
Nicolas Cadieux
njacadieux.gitlab at gmail.com
Thu Nov 19 18:48:20 PST 2020
Nice to know you got it going.
Cheers!
Nicolas Cadieux
https://gitlab.com/njacadieux
> Le 19 nov. 2020 à 21:44, Prakash g <prak15ash at gmail.com> a écrit :
> Yes it is. Actually Your answer has two solutions which I found the following
> 1. It works when I change my .shp file to geopackage format I mean toggle edit button enabled.
> 2. Even though the browser panel shows the .shp file for me which I have exported to Qgis, We have to individually extract all the zip files which we have downloaded in our file manager. When doing so the toggle edit button is enabled.
> Hope it helps and Thankyou once again.
>> On Thu, 19 Nov, 2020, 10:40 pm Nicolas Cadieux, <njacadieux.gitlab at gmail.com> wrote:
>> Did it work?
>> If so reply to the mailing list so others will fix the problem in the futur!
>> Cheers!
>> Nicolas Cadieux
>>>> Le 19 nov. 2020 à 10:30, Prakash g <prak15ash at gmail.com> a écrit :
>>> Thank you so much.
>>>> On Thu, 19 Nov, 2020, 6:38 pm Nicolas Cadieux, <njacadieux.gitlab at gmail.com> wrote:
>>>> Hi,
>>>> I have had this problem before with files exported from AutoCAD Map3D. They only had 2 additional files plus the file with the .shp extension (3 in all). I could not place the file in editing mode. Problem was solved by simply re-saving the file under a different name. I would export the file to a geopackage format. That is better than the .shp format in most cases. After that, you should be able to turn on the editing before editing the file.
>>>> Nicolas Cadieux
>>>>>> Le 18 nov. 2020 à 23:48, Prakash g <prak15ash at gmail.com> a écrit :
>>>>> Hello,
>>>>> I m new to qgis using qgis 3.16(Hannover) in MX LINUX OS. The problem is when I load a shp file (ie) .shp file and do click the particular file to edit some features like merge or delete , my toggle edit(âï¸) is still grey. I tried all the plugins installed and also project --> properties--> data sources and not ticking the READ ONLY option. Kindly figure out the problem. Waiting eagerly for your reply .
>>>>> Below i ll attach some screen shots. As you see the TOGGLE EDIT is grey ..
>>>>> Thankyou .. Hoping that i m not distrubing you.
>>>>> <IMG-20201119-WA0002.jpeg>
>>>>> <IMG-20201119-WA0004.jpeg>
>>>>> <IMG-20201119-WA0000.jpeg>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201119/acc37e5d/attachment.html>
