Hi, is there a way to have a feature on map and when I press/click/hover on it that some event is raised? Primary I want to toggle an attribute field true/false. I than will e.g. display a special symbol(layer) to an other feature. Example: Feature A has a foreign key to Feaure B, when B is hovered then A's symbol should be yellow instead of green. Regards
