[Qgis-user] Vote for Lat Lon Tools Default Coordinate Order - YX or XY
Christoph Jung
jagodki.cj at gmail.com
Sat Nov 21 03:34:06 PST 2020
My personal opinion is, that GIS should think more in a mathematic way. Because of that, I always prefer working with XY-values, no matter which CRS I am using. It is always a mess for your work, if data using YX-values, and you will analyse your data with mathematic formulas. The usage of lat Lon is only a speaking and survey thing...
Sincerely,
Christoph
> Am 20.11.2020 um 18:11 schrieb C Hamilton <adenaculture at gmail.com>:
> It was suggested to me that the default coordinate order in the Lat Lon Tools plugin for coordinate capture and zoom-to tools should be "longitude, latitude" or "X, Y". Originally, Lat Lon Tools was designed to work with on-line maps which are generally "latitude, longitude" order.
> You can always go into the plugin settings and specify which order you want and that order will be preserved everytime you launch QGIS. The default order is only applicable the first time you install "Lat Lon Tools" or if you do a reset to defaults in the Lat Lon Tools settings menu,
> Who prefers Lat Lon Tools to default to "longitude, latitude" or "X, Y" when the plugin is first installed or reset to default values?
> Who prefers Lat Lon Tools to default to "latitude, longitude (Google map order)" or "Y, X" when the plugin is first installed or reset to default values?
> I'm just checking to see if I should make this change or not.
> Thanks,
> Calvin
> Qgis-user mailing list
