[Qgis-user] Toggle Attribute
Bernd Vogelgesang
bernd.vogelgesang at gmx.de
Sun Nov 22 11:01:53 PST 2020
if you would be so kind to explain the "just" part of your proposal?
On 22.11.20 15:56, Jésahel Benoist wrote:
> Can't you just use layer's actions?
> djes
> Le dim. 22 nov. 2020 à 08:43, Bernd Vogelgesang <bernd.vogelgesang at gmx.de>
> a écrit :
>> I had a similiar use case, see here:
>> https://gis.stackexchange.com/q/322544/8202
>> Unfortunately, I just noticed the answer on my post then right now, so I
>> did not dig any deeper.
>> Basic thing is, that you can establish a "connection" between two layers
>> by an "aggregate" function.
>> But how to use that to change the style on e.g. a hover, is still beyond
>> my capabilities, but I'm prettey sure there is some clever way to
>> accomplish that. Sadly, I'm not that clever. Maybe something with rule
>> based style?
>> Cheers,
>> Bernd
>> On 21.11.20 11:51, L.W. wrote:
>>> Hi,
>>> is there a way to have a feature on map and when I press/click/hover on
>>> it that some event is raised?
>>> Primary I want to toggle an attribute field true/false.
>>> I than will e.g. display a special symbol(layer) to an other feature.
>>> Example: Feature A has a foreign key to Feaure B, when B is hovered then
>>> A's symbol should be yellow instead of green.
>>> Regards
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
