[Qgis-user] Toggle Attribute
Richard Duivenvoorde
rdmailings at duif.net
Mon Nov 23 00:40:59 PST 2020
On 11/22/20 8:40 PM, Jésahel Benoist wrote:
> The actions are a standard way of acting on graphical objects, so for me it would be the first thing to try. Did you ?
> Le dim. 22 nov. 2020 à 20:01, Bernd Vogelgesang <bernd.vogelgesang at gmx.de <mailto:bernd.vogelgesang at gmx.de>> a écrit :
> if you would be so kind to explain the "just" part of your proposal?
I think in the User lists it is always good to add a link to some documentation about a QGIS-term. In this case 'actions' kan be a normal word, but (advanced) users maybe (or not) know that it is also something you can use to 'do something in QGIS upon a click on a feature'.
Some documentation here:
https://docs.qgis.org/testing/en/docs/user_manual/working_with_vector/vector_properties.html#actions-menu
(or do a search on 'actions' in the QGIS docs site).
Tip: go to vector layer properties, 'Actions' tab, and hit 'Create Default Actions' button. You will get all kind of examples.
About original post: I do not think we have an Action on hover (plz correct me if I'm wrong), but to run some (PyQGIS) python code is doable.
With PyQGIS you can search for features in other layers, and maybe 'select' these on click in the other layer (or change attribute, though I'm not sure how to change it back then... )
Acutally this sounds like nice functionality for layers which have relations... I'm not so experienced with relations in layers.
If you worked out a way to do this, plz let us know :-)
Regards,
Richard
