[Qgis-user] 202021-ESRI gdb not opening on macOS Big Sur Version 11.0.1
Paul T A Drea
pauldrea at gmail.com
Mon Nov 23 04:51:35 PST 2020
Hi all,
Have tried it on QGIS 3.14 with the same results.
I do not believe it is a problem with QGIS per se but the libraries with
Big Sur.
I will hold off for a while and work on the Ubuntu machine which has no
problem.
Thanks for the help.
BR
Paul
On 23/11/2020 13:45, John Layt wrote:
> Hi,
> It may be the difference is between QGIS 3.14 and 3.16, as the Mac
> packaging method changed in 3.16 and there are a few
> residual problems that are fixed in 3.16.1 (hopefully out today). I'd
> test it first with 3.14 on Big Sur before downgrading to Catalina.
> Regards,
> John.
> On Sat, 21 Nov 2020 at 08:03, Paul T A Drea <pauldrea at gmail.com
> <mailto:pauldrea at gmail.com>> wrote:
> Hi Ujaval,
> Same error. I am hearing from a colleage that this macOS version
> is missing some of the lbraries that were in Catalina.
> I am updating all my backups and will bite the bullet and roll
> back to Catalina.
> Thanks for the quick response.
> BR
> Paul
> On 21/11/2020 11:52, Ujaval Gandhi wrote:
>> I just ran into this and looks like a bug. Apparently dragging
>> and dropping layers from the Browser panel works perfectly. Do
>> try and see if that's the case.
>> Logo <https://spatialthoughts.com/>
>> Ujaval Gandhi
>> Spatial Thoughts
>> mobile: +91-8095684687
>> email: ujaval at spatialthoughts.com
>> <mailto:ujaval at spatialthoughts.com>
>> LinkedIn icon <https://www.linkedin.com/in/spatialthoughts/>
>> Twitter icon <https://twitter.com/spatialthoughts>
>> On Sat, Nov 21, 2020 at 12:27 PM Paul T A Drea
>> <pauldrea at gmail.com <mailto:pauldrea at gmail.com>> wrote:
>> Dear list,
>> I am running QGIS 3.16.0-Hannover QGIS code revision
>> 4af1cbfb97 on a macOS Big Sur platform.
>> Below is the error message I get when I try to open an ESRI
>> gdb file.
>> 2020-11-21T10:36:46 CRITICAL Invalid Data Source :
>> /Volumes/PAUL SSD
>> 3/_Verif-i_UAE_2019/04.Data/02.GIS/03.Shapefiles/5.BLOCK_7_NORTH/Facilities_OnshoreBlock7.gdb
>> is not a valid or recognized data source.
>> This same file opens on my Ubuntu 20.04 machine and Win10
>> machine running QGIS 3.14.1-Pi QGIS code version de08d6b71d
>> with no problems.
>> This has only become apparent after an update on macOS from
>> Catalina v10.15 to Big Sur 11.0.1
>> Has anyone else experienced this problem?
>> Any help in solving this would be much appreciated.
>> Thank you and BR.
>> Paul
>> */Paul T. A. Drea/*
>> *Geodetic Consultant*
>> *Cell Greece: +30-698 052 0611*
>> *Cell Abu Dhabi: +971 50 595 6547*
>> *Cell U.K.: +44 7507 975162*
>> *SKYPE: paul.drea*
>> *e**-mail 1: **pauldrea at gmail.com* <mailto:pauldrea at gmail.com>
>> *e**-mail 2: **ptadrea at otenet.gr* <mailto:ptadrea at otenet.gr>
>> Qgis-user mailing list
>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> <https://lists.osgeo.org/mailman/listinfo/qgis-user>
>> Unsubscribe:
> */Paul T. A. Drea/*
> *SKYPE: paul.drea*
*/Paul T. A. Drea/*
*SKYPE: paul.drea*
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201123/afa8c1bd/attachment.html>
