[Qgis-user] Toggle Attribute
Mike Flannigan
mflan at mflan.com
Mon Nov 23 17:21:42 PST 2020
Thank you. I did get an Action to operate today. My action also
uses a Google Maps link.
I can click on "Identify Features", which opens a "Identify Results"
panel. Then I can click on a feature in that layer, open Actions
in the "Identify Results" panel, and click on the action, which
runs the action.
Now I'm trying to make the action more accessible. Am I correct
in my assumption that the button just to the right of "Identify Features"
should list my Action in the dropdown list? So list stuff like this:
http://www.mflan.com/temp/action1.jpg
Figure 5 was taken from:
https://www.geodose.com/2018/04/qgis-tutorial-how-to-create-action.html
When I click on that little black triangle on the button just to the right
of "Identify Features" it shows an empty, white box. When I click on the
button is doesn't do anything. When I hover over the button it says
"no action selected".
Ideally I would like for the action to run if I just click on the feature.
Mike
On 11/23/20 2:00 PM, qgis-user-request at lists.osgeo.org wrote:
> Hi Mike,
> Just create an action with something like this to see it in action:
> https://www.google.pt/maps/@[% @click_x %],[% @click_y %]
> This will open google maps at the place you clicked. If you want to get
> something from the action called, you have to capture its output (and
> return the right value from your script).
> As Richard said, start with the default actions and you will see
> different kinds of things that can be done with actions. Capturing the
> clicked X,Y is straight forward.
> Jorge
