[Qgis-user] Polygon from 4 points
Ryan Peel ryanpeel at gmail.com
Thu Nov 26 07:16:10 PST 2020
Thank you!  Worked PERFECT!
On Thu, Nov 26, 2020 at 10:02 AM Totò Fiandaca <pigrecoinfinito at gmail.com>
wrote:
> From Processing:
> search for Geometry by Expression:
> 1. as input layer put your file with the coordinates
> 2. and write this expression:
>   make_polygon (
>   make_line (
>   make_point ("x1", "y1"),
>   make_point ("x2", "y2"),
>   make_point ("x3", "y3"),
>   make_point ("x4", "y4")
> and launch the geoprocess.
> I used QGIS 3.16 Hannover
> Il giorno gio 26 nov 2020 alle ore 15:48 Ryan Peel <ryanpeel at gmail.com>
> ha scritto:
>> I have a csv/table that has a single row that contains some metadata as
>> well as four SEPARATE columns, x1, y1, x2, y2, x3, y3, x4, y4 of decimal
>> degree coordinates.
>> I want to import all of this data into QGIS and create a polygon from the
>> four points as a vector layer.
>> What is the best way to do this?  I'm not a programmer or scripter really
>> and fairly new to QGIS.
>> Thanks!
>> *Ryan Peel*
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> *Ing. Salvatore Fiandaca*
> *mobile*.:+39 327.493.8955
> *m*: *pigrecoinfinito at gmail.com <pigrecoinfinito at gmail.com>*
> *C.F*.: FNDSVT71E29Z103G
> *P.IVA*: 06597870820
> *membro QGIS Italia - http://qgis.it/ <http://qgis.it/>*
> *socio GFOSS.it - *http://gfoss.it/
> *blog:*
> * https://pigrecoinfinito.com/ <https://pigrecoinfinito.com/> FB: Co-admin
> - https://www.facebook.com/qgis.it/ <https://www.facebook.com/qgis.it/>**
> <https://www.facebook.com/qgis.it/> *
> *TW:  <http://goog_95411464>**https://twitter.com/totofiandaca
> <https://twitter.com/totofiandaca>*
> 43°51'0.54"N  10°34'27.62"E - EPSG:4326
> “Se la conoscenza deve essere aperta a tutti,
> perchè mai limitarne l’accesso?”
> R. Stallman
> Questo documento, allegati inclusi, contiene informazioni di proprietà di
> FIANDACA SALVATORE e deve essere utilizzato esclusivamente dal destinatario
> in relazione alle finalità per le quali è stato ricevuto. E' vietata
> qualsiasi forma di riproduzione o divulgazione senza l'esplicito consenso
> di FIANDACA SALVATORE. Qualora fosse stato ricevuto per errore si prega
> di informare tempestivamente il mittente e distruggere la copia in proprio
> possesso.
*Ryan Peel*
*President, Vergennes Broadband LLCRural Fiber and Wireless
Broadbandwww.vergennesbroadband.com
<http://www.vergennesbroadband.com>**616-897-3107
(o)  616-821-3766 (m)*
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201126/2b145745/attachment.html>
