[Qgis-user] Polygon from 4 points
Raymond Nijssen r.nijssen at terglobo.nl
Fri Nov 27 00:37:18 PST 2020
Hi Ryan,
I think you could create a python QgsVectorDataProvider for your data
and setup a QGIS server for hosting a wms.
https://www.itopen.it/qgis-vector-data-provider-python/
But I would probably just go for a simple script that converts the csv
file into a polygon dataset (gpkg, shp, postgis, ..) and create a wms
based on that.
Kind regards,
Raymond
On 26-11-2020 19:10, Ryan Peel wrote:
> Extending this thought a little.  Is there a way to create a WMS service
> from this so that the WMS reads a csv file, automatically creates the
> polygons using the expression that Toto recommended, so that it (on the
> fly) creates the polygons from adding the WMS to a map so I can share
> with my co-workers so that we are all using the updated data (rather
> than having to share a shp file).
> Long question, hoping for maybe an easy solution.
> Ryan
> VB Fiber
> On Thu, Nov 26, 2020 at 12:59 PM Ujaval Gandhi
> <ujaval at spatialthoughts.com <mailto:ujaval at spatialthoughts.com>> wrote:
>     Totò - really great solution! Didn't know about Geometry by
>     Expression and it will come in handy for sure.
>     Logo <https://spatialthoughts.com/>
>     Ujaval Gandhi
>     Spatial Thoughts
>     mobile: +91-8095684687
>     email: ujaval at spatialthoughts.com <mailto:ujaval at spatialthoughts.com>
>     LinkedIn icon <https://www.linkedin.com/in/spatialthoughts/> Twitter
>     icon <https://twitter.com/spatialthoughts>
>     On Thu, Nov 26, 2020 at 8:33 PM Totò Fiandaca
>     <pigrecoinfinito at gmail.com <mailto:pigrecoinfinito at gmail.com>> wrote:
>          From Processing:
>         search for Geometry by Expression:
>         1. as input layer put your file with the coordinates
>         2. and write this expression:
>            make_polygon (
>            make_line (
>            make_point ("x1", "y1"),
>            make_point ("x2", "y2"),
>            make_point ("x3", "y3"),
>            make_point ("x4", "y4")
>         and launch the geoprocess.
>         I used QGIS 3.16 Hannover
>         Il giorno gio 26 nov 2020 alle ore 15:48 Ryan Peel
>         <ryanpeel at gmail.com <mailto:ryanpeel at gmail.com>> ha scritto:
>             I have a csv/table that has a single row that contains some
>             metadata as well as four SEPARATE columns, x1, y1, x2, y2,
>             x3, y3, x4, y4 of decimal degree coordinates.
>             I want to import all of this data into QGIS and create a
>             polygon from the four points as a vector layer.
>             What is the best way to do this?  I'm not a programmer or
>             scripter really and fairly new to QGIS.
>             Thanks!
>             *Ryan Peel*
>             _______________________________________________
>             Qgis-user mailing list
>             Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>             List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>             Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>         *Ing. Salvatore Fiandaca*
>         *mobile*.:+39 327.493.8955
>         *m*: *pigrecoinfinito at gmail.com <mailto:pigrecoinfinito at gmail.com>*
>         *C.F*.: FNDSVT71E29Z103G
>         *P.IVA*: 06597870820
>         *membro QGIS Italia - http://qgis.it/*
>         *socio GFOSS.it - *http://gfoss.it/
>         *blog:** https://pigrecoinfinito.com/
>         <https://pigrecoinfinito.com/>
>         FB: Co-admin -
>         https://www.facebook.com/qgis.it/**<https://www.facebook.com/qgis.it/>
>         *TW:<http://goog_95411464>**https://twitter.com/totofiandaca*
>         43°51'0.54"N  10°34'27.62"E - EPSG:4326
>         “Se la conoscenza deve essere aperta a tutti,
>         perchè mai limitarne l’accesso?”
>         R. Stallman
>         Questo documento, allegati inclusi, contiene informazioni di
>         proprietà di FIANDACA SALVATORE e deve essere utilizzato
>         esclusivamente dal destinatario in relazione alle finalità per
>         le quali è stato ricevuto. E' vietata qualsiasi forma di
>         riproduzione o divulgazione senza l'esplicito consenso di
>         FIANDACA SALVATORE. Qualora fosse stato ricevuto per errore si
>         prega di informare tempestivamente il mittente e distruggere la
>         copia in proprio possesso.
