[Qgis-user] z factor
Raymond Nijssen r.nijssen at terglobo.nl
Fri Nov 27 01:52:23 PST 2020
Hi Nicolas,
It is just a simple formula for calculating the "z-factor" for a given
latitude. What would that look like in a plugin? Where would it go? What
would it do or show?
Last week I had a similar idea for a plugin that could tell you which
UTM zone to pick for your current canvas. I decided it would not be
worth the effort. But maybe these could go together (and be finished at
the end of this "KwakFriday"?
Regards,
Raymond
On 27-11-2020 06:13, Nicolas Cadieux wrote:
> Hi,
> It's just the Z factor needed when you make a hillshade when the x an y
> are in degrees and the z is in feet or meters (like SRTM). You can see
> it if you choose Hillshade under symbology / render type (for a raster
> layer).  It's basically the length of a degree in meters for latitude.
> https://www.esri.com/arcgis-blog/products/product/imagery/setting-the-z-factor-parameter-correctly/
> Nicolas
> On 2020-11-27 12:08 a.m., Richard Duivenvoorde wrote:
>> On 11/27/20 5:28 AM, Nicolas Cadieux wrote:
>>> I want to learn to make a QGIS plugin and I was wondering if anybody
>>> new if there is a QGIS plugin or tool that calculates the z factor
>>> for a particular latitude? I thought this would be an easy project to
>>> start with but I don't want to duplicate someone else's work.
>> Hi Nicolas,
>> What do you mean with "calculates the z factor for a particular
>> latitude"?
>> - z-factor as in x,y,z?
>> - Do you mean based on a crs/datum? So more proj-based?
>> - Or do you mean based on a known dataset with not enough z-info? So
>> more extra/intrapolation?
>> - Raster? Vector?
>> - Creating a new dataset (processing)? Or just reporting for one lat
>> (desktop/gui)?
>> Just trying to get an idea of your idea :-)
>> Regards,
