[Qgis-user] z factor
Nicolas Cadieux
njacadieux.gitlab at gmail.com
Fri Nov 27 06:57:39 PST 2020
I did suggest it indeed. Ideally, it would go in the QGIS core every time they ask for a z factor. (Like under shading in the layer style). I will probably play around with it just to learn who to make a plugin but if you want to put it in your plugin, go ahead.
Nicolas Cadieux
https://gitlab.com/njacadieux
> Le 27 nov. 2020 à 08:43, C Hamilton <adenaculture at gmail.com> a écrit :
> I have a Lat Lon Tools plugin, Field Calculator function that generates the UTM zone.
> Nicolas, you just reminded me that you had suggested this to me earlier as a plugin. Something like that would be easy to add, but I'm not sure it fits within Lat Lon Tools which captures different coordinates, but z-factor is related to the latitude so perhaps it fits.
> Does anyone think it would be worth adding to Lat Lon Tools or should it be a separate plugin?
> Calvin
>> On Fri, Nov 27, 2020 at 4:52 AM Raymond Nijssen <r.nijssen at terglobo.nl> wrote:
>> Hi Nicolas,
>> It is just a simple formula for calculating the "z-factor" for a given
>> latitude. What would that look like in a plugin? Where would it go? What
>> would it do or show?
>> Last week I had a similar idea for a plugin that could tell you which
>> UTM zone to pick for your current canvas. I decided it would not be
>> worth the effort. But maybe these could go together (and be finished at
>> the end of this "KwakFriday"?
>> Regards,
>> Raymond
>> On 27-11-2020 06:13, Nicolas Cadieux wrote:
>> > Hi,
>> > It's just the Z factor needed when you make a hillshade when the x an y
>> > are in degrees and the z is in feet or meters (like SRTM). You can see
>> > it if you choose Hillshade under symbology / render type (for a raster
>> > layer). It's basically the length of a degree in meters for latitude.
>> > https://www.esri.com/arcgis-blog/products/product/imagery/setting-the-z-factor-parameter-correctly/
>> > Nicolas
>> > On 2020-11-27 12:08 a.m., Richard Duivenvoorde wrote:
>> >> On 11/27/20 5:28 AM, Nicolas Cadieux wrote:
>> >>> I want to learn to make a QGIS plugin and I was wondering if anybody
>> >>> new if there is a QGIS plugin or tool that calculates the z factor
>> >>> for a particular latitude? I thought this would be an easy project to
>> >>> start with but I don't want to duplicate someone else's work.
>> >> Hi Nicolas,
>> >> What do you mean with "calculates the z factor for a particular
>> >> latitude"?
>> >> - z-factor as in x,y,z?
>> >> - Do you mean based on a crs/datum? So more proj-based?
>> >> - Or do you mean based on a known dataset with not enough z-info? So
>> >> more extra/intrapolation?
>> >> - Raster? Vector?
>> >> - Creating a new dataset (processing)? Or just reporting for one lat
>> >> (desktop/gui)?
>> >> Just trying to get an idea of your idea :-)
>> >> Regards,
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201127/aca27a98/attachment.html>
