[Qgis-user] Show multiple photos attached to one feature
Jésahel Benoist
djes1975 at gmail.com
Sat Oct 17 11:20:28 PDT 2020
Did you simply try a drag'n'drop custom form ? It's not a well documented
feature but it's really easy to use. In the layer properties, go to
[image: image.png]
And for all the pictures fields, choose attachment as widget type and the
following options (click on the left panel to choose the field, the middle
panel is to arrange the fields)
[image: image.png]
Now, your form is able to display correctly any numbers of well
dimensioned pictures. Use the middle panel to group them, create tabs or
containers (a bit tedious, but it works !)
Regard,
djes
Le sam. 17 oct. 2020 à 13:33, Bernd Vogelgesang <bernd.vogelgesang at gmx.de>
a écrit :
> Hi Brent,
> thanx for sharing your solution.
> I think, there is quite some need for some core functionality in QGIS for
> handling photos, as this quite a common need for a lot of people.
> Just this week, there was this conversation about the removal of the eVIS
> plugin in QGIS3.
> Those hacks of you are nice, but far beyond the abilities of normal users
> (apart form the fact the this information will never be found by anyone
> anymore, buried in this mailing list)
> Would be so nice to have a flexible in-QGIS-solution for geotagged image
> viewing along with its associated data without cumbersom hacks.
> Having a working standard tool, one could adjust the workflows to just
> this tool, and lots of people would be happy (including me, dealing with a
> lot of photos too)
> I hope one day there will be a crowdfunding for such a tool, as it seems
> this area is quite out of scope of the core developers.
> Cheers,
> Bernd
> On 17.10.20 06:55, Brent Wood wrote:
> Hi Sophia,
> I suggest you set up a QGIS Action on the layer to view the images for a feature.
> For a single feature, your data needs to contain a field with all the image names space separated (so no whitespace within names unless you want to make life difficult!!).
> The action will be a batch file (Windows - painful, or Powershell) or script (Linux/Mac - easy) concatenate the path to each filename, then open each file with an image viewer.
> eg:
> a point feature has this text as a field (called filename):
> (the names of two pictures associated with the point feature)
> I write a simple shell script (I'm on Linux) to iterate through a list of files (I called it open_images):
> #! /bin/bash
> # iteratively opens images passed on the command line
> FILES=$@
> for FILE in $FILES ; do
> eom /home/baw/Pictures/$FILE
> done
> The bash script sets the "$FILES" variable to store the list passed on the command line ($@)
> It then uses the eom program (simple Linux image viewing program) to iteratively open each file in the list,
> prepending the path to the file for each one.
> In QGIS, I create an Action on this layer called "open image", it contains the command:
> /home/baw/qgis/open_images [%filename%]
> This is the path to my my script, followed by the list of image names.
> So, if I then select the action tool in QGIS, when I click on a feature on the canvas, QGIS runs the command as set up in the action, which is my script. It passes the contents of the "filename" field for the feature as a command line parameter. (essentially runs the command: /home/baw/qgis/open_images P1010005.JPG P1020700.JPG
> The script then shows the first file, then the second, etc. whenever you click on a feature in QGIS. You can have a list with as many images per feature as you like (within reason... 30000 might be a problem!!
> Hope this helps, I find the Action tool very useful for this sort of thing. Not quite as easy in Windows, which is not primarily a command line setup, but can still be done.
> Cheers
> Brent Wood
> Principal Technician, Fisheries
> NIWA
> DDI: +64 (4) 3860529
> ________________________________
> From: Qgis-user <qgis-user-bounces at lists.osgeo.org> <qgis-user-bounces at lists.osgeo.org> on behalf of chris hermansen <clhermansen at gmail.com> <clhermansen at gmail.com>
> Sent: Saturday, October 17, 2020 16:20
> To: sophia couchman <choccycouchman at iname.com> <choccycouchman at iname.com>
> Cc: qgis-user <qgis-user at lists.osgeo.org> <qgis-user at lists.osgeo.org>
> Subject: Re: [Qgis-user] Show multiple photos attached to one feature
> Sophia and list,
> On Fri, Oct 16, 2020, 06:20 sophia couchman <choccycouchman at iname.com<mailto:choccycouchman at iname.com> <choccycouchman at iname.com>> wrote:
> Hi All,
> I have mapped individual trees in a wood using QGIS and QField in a Layer called Trees. Each Tree/Feature contains a number of fields. I included a field for taking photographs and for each tree I took a number of photographs, anywhere from 2 to 6.
> I then brought the QField data onto the computer. When I right click on an individual feature using the Identify Features arrow the Identify Results box appears. It contains all the fields including the photo field but this contains only one photograph in this format- DCIM/trees_20201010165100197.jpg but not the rest. How can I have the rest of the photographs listed here too?
> I think that if you have up to six photos you are going to need up to six fields to put them in, are you not?
> Alternatively you could have a oneto zero or many relationship between your tree table and a separate photo table, which may be more difficult for you to manage.
> Some databases will support an array of items but not sure if / how that is manifested in QGIS.
> Chris
> [https://www.niwa.co.nz/static/niwa-2018-horizontal-180.png]<https://www.niwa.co.nz> <https://www.niwa.co.nz>
> Brent Wood
> Principal Technician - GIS and Spatial Data Management
> Programme Leader - Environmental Information Delivery
> +64-4-386-0529 |
> National Institute of Water & Atmospheric Research Ltd (NIWA)
> 301 Evans Bay Parade Hataitai Wellington New Zealand
> Connect with NIWA: niwa.co.nz<https://www.niwa.co.nz> <https://www.niwa.co.nz> Facebook<https://www.facebook.com/nzniwa> <https://www.facebook.com/nzniwa> LinkedIn<https://www.linkedin.com/company/niwa> <https://www.linkedin.com/company/niwa> Twitter<https://twitter.com/niwa_nz> <https://twitter.com/niwa_nz> Instagram<https://www.instagram.com/niwa_science> <https://www.instagram.com/niwa_science>
> To ensure compliance with legal requirements and to maintain cyber security standards, NIWA's IT systems are subject to ongoing monitoring, activity logging and auditing. This monitoring and auditing service may be provided by third parties. Such third parties can access information transmitted to, processed by and stored on NIWA's IT systems
> Qgis-user mailing listQgis-user at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201017/dcc7b9b2/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201017/dcc7b9b2/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201017/dcc7b9b2/attachment-0003.png>
