[Qgis-user] QGIS and SAGA 7.3.0
Bernd Vogelgesang bernd.vogelgesang at gmx.de
Sun Oct 18 03:25:56 PDT 2020
ah, just found the issue again on gis.stackexchange
https://gis.stackexchange.com/a/346558/8202
Excerpt from my solution:
"... The workflow should be:Install the SAGA Nextgen Provider and then
deactivate it by unchecking the checkbox. Then change the version number
to 7.3. in provider.py under
/.local/share/QGIS/QGIS3/profiles/default/python/plugins/processing_saga_nextgen/processing
. Then reactivate the plugin in the plugin manager ..."
On 18.10.20 11:51, Nick Hopton wrote:
> The SAGA NexGen plugin is flagged as 'Experimental', which I think means 'it
> may not work for you' - this is fair enough.
> I see that SAGA 2.2.5 is still in the repository so I think I'll do away
> with Version 7.3.0 in the short term and fall back on the older version,
> calling it from the Processing Toolbox as I used to.
> Many thanks for the suggestions, I'm always amazed at how helpful people
> are.
> All the best,
> Nick.
> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201018/fa9d324b/attachment.html>
