[Qgis-user] QGIS and SAGA 7.3.0
Bernd Vogelgesang
bernd.vogelgesang at gmx.de
Sun Oct 18 14:49:51 PDT 2020
Great!
Seems we are hacking us along ;)
OMG
On 18.10.20 22:25, Rien Boydens wrote:
> Hi Nick
> This seems to be a bug in SAGA NextGen. I'm already looking to file a
> pull request, but you could also quickly fix it for yourself by going
> to
> .local/share/QGIS/QGIS3/profiles/default/python/plugins/processing_saga_nextgen/description/SimpleFilter.txt
> and changing "MODE" to "KERNEL_TYPE" and "RADIUS" to "KERNEL_RADIUS".
> You might also do it in SimpleFilerwithinshape.txt if you want that
> one to work as well.
> Wish you good luck
> Rien
> On 18/10/2020 20:57, Nick Hopton wrote:
>> Hi berndv,
>> I thought we might be getting somewhere with your last suggestion, I
>> made
>> the changes you mentioned and the SAGA NextGen tools duly appeared. I
>> then
>> tried to run the SAGA Simple filter on a one-metre DTM, but this
>> failed with
>> the message 'Unknown option 'MODE''. This is a step forward of
>> course, I'd
>> not managed QGIS/NexGen to recognise SAGA at all before this. Here's
>> part of
>> the output from the log:
>> 2020-10-18T19:22:34 INFO SAGA execution commands
>> io_gdal 0 -TRANSFORM 1 -RESAMPLING 3 -GRIDS
>> "/tmp/processing_LzwXIT/b240a8bf0bac43518ec759524cb8b9d0/DTMSU5565P107172019012320190325.sgrd"
>> -FILES
>> "/home/nick/Desktop/bucklebury_common/P_10717/DTM_SU5565_P_10717_20190123_20190325.tif"
>> grid_filter "Simple Filter" -INPUT
>> -MODE 0 -METHOD 0 -RADIUS 25 -RESULT
>> "/tmp/processing_LzwXIT/a2d7f23262044c1faa1105e743070c85/RESULT.sdat"
>> 2020-10-18T19:22:36 INFO SAGA execution console output
>> ____________________________
>> SAGA Version: 7.3.0
>> library path: /usr/lib/x86_64-linux-gnu/saga/
>> library name: libio_gdal
>> library : io_gdal
>> tool : Import Raster
>> identifier : 0
>> author : O.Conrad (c) 2007 (A.Ringeler)
>> processors : 12 [12]
>> Parameters
>> Grids: No objects
>> Files:
>> Multiple Bands Output: automatic
>> Select from Multiple Bands:
>> Transformation: true
>> Resampling: B-Spline Interpolation
>> loading:
>> Driver: GTiff
>> Bands: 1
>> Rows: 5000
>> Columns: 5000
>> loading:
>> SAGA Version: 7.3.0
>> library name: libgrid_filter
>> library : grid_filter
>> tool : Simple Filter
>> identifier : 0
>> author : O.Conrad (c) 2003
>> I'm not entirely sure where I go from here!
>> All the best,
>> Nick.
>> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
