[Qgis-user] Shared/common library for PyQGIS scripts
Charles Dixon-Paver charles at kartoza.com
Tue Oct 20 02:20:17 PDT 2020
I agree that the cookbook is a great resource (which is why I put it first
on my list), but I think it's better suited to general examples and giving
a solid outline of the best practices. If it's not kept concise, it could
become a bit of a convoluted mess, in addition to all the broken code
issues Richard raises.
As much as it provides a place for scripts that have common use cases,
there are some scripts I feel are useful to the community that have no
place there, nor do they warrant their own plugin.
For example, if you wanted to print out a list of all the typefaces used in
a project, AFAIK there's a fair number of nested attributes you have to
loop through which I expect a novice would find rather challenging. At the
same time, this hardly seems a relevant use case for the cookbook. In GIS,
I find a lot of people who aren't developers find themselves with a need to
leverage code, so having a way to support copy-paste programmers is
beneficial in my view, but maybe that's just me.
On Tue, 20 Oct 2020 at 10:59, Richard Duivenvoorde <rdmailings at duif.net>
wrote:
> On 10/20/20 10:48 AM, Jorge Gustavo Rocha wrote:
> > Hi,
> > I think the PyQGIS Cookbook is the perfect place to share these scripts.
> The Cookbook is not the API reference documentation. It is the place to
> share solutions for common problems using the QGIS API.
> While I agree with this, note that it currently is not 'simple' to paste
> some scripts in the cookbook.
> Because the cookbook became ... uh a mess, because there were non-running
> old examples in it, the cookbook is now build in a way that the examples IN
> the cookbook are actually ran/tested (against/in a Docker QGIS instance).
> This means that if some api changes, the build of the cookbook of the
> examples using that api would make the build fail. Which is a good check.
> But... it also means that 'just copy pasting' some handy examples is not
> so easy. You have to make sure that there is data to work with, or make
> some mockup first to be able an example etc etc...
> So: yes, the cookbook is a good place to showoff use of PyQGIS examples
> (and to show the use of (sometimes not so intuitive) PyQGIS api)... but for
> practical examples, it takes (for an average PyQGIS user) maybe too much
> energy?
> OR (not sure if that is possible) we should add some 'sketchy' page where
> indeed people can add working examples and which are not tested... (and
> which will probably become stale and nobody cares to fix them... like the
> old cookbook examples)
> Not sure what others think about this though...
> Regards,
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201020/13f6167d/attachment.html>
