[Qgis-user] Live Mapping with QGIS on Toughbook
Randal Hale
rjhale at northrivergeographic.com
Tue Sep 1 07:22:57 PDT 2020
It does on Linux. It's always worked well for me after I stumble through
setting up things. I should write it down....but haven't.
I'm wondering though can you connect Bluetooth to GPSD - In other words
can I connect my Linux Laptop to my phones GPS and still use GPSD? I've
not tried mostly hadn't had the time or the "wanderlust" to work through
the process. I assume you can. There's not much you can do these days
with a linux workstation.
Randy
On 9/1/20 9:16 AM, Greg Troxel wrote:
> Randal Hale <rjhale at northrivergeographic.com> writes:
>> I guess that's the one area I am fuzzy on is How QGIS interacts with
>> GPS's. It seems like it's looking for either a com or USB port. Which
>> with lets say you have a Bluetooth I'm not sure what you would do (I
>> have yet to do the Bluetooth -> laptop -> QGIS Dance because I don't
>> hate my life enough currently). I've connected external GPS (USBs)
>> alot using GPSgate and supposedly Windows 10 will let you do the same
>> thing if you configure the settings.....I guess that depends on How
>> the GPS is hooked into the Laptop.
> Coming from Unix, I would expect qgis to talk to gpsd, which would
> manage whatever kind of GNSS receiver you have. There is no good reason
> from a software organization viewpoint to replicate code dealing with
> the various kinds of things in multiple programs that just need
> position. But, if it's just "connect to this address/port and expect
> NMEA", it's not so bad.
Randal Hale
(p) 423.653.3611
http://www.northrivergeographic.com
