[Qgis-user] Mac computer configuration
Donal Hunt donal.hunt at gmail.com
Wed Sep 9 02:05:44 PDT 2020
Can you provide the following information from the command line (run these
commands and paste the output):
*$* system_profiler SPHardwareDataType
*$* system_profiler -detailLevel mini SPSerialATADataType SPParallelATADataType
** you may want to remove/redact the "Serial Number (system)" and "Hardware
UUID" values before emailing.*
That will provide some information on your existing system and disks which
will make it easier to determine what appropriate replacements are needed.
Normally, I would look at CPU performance, amount of RAM and disk speeds
(HDD vs SSD vs NVMe makes a huge difference).
Hope that helps!
Donal
On Wed, 9 Sep 2020 at 02:00, RMG <reikogoodwin at gmail.com> wrote:
>  Hello QGIS users on Macs,
> I would like advice on purchasing a new Mac. My Mac is 5 years old and
> cannot handle heavy-duty QGIS procedures. I process many satellite images
> and some vector files with 30 m grids have millions of features, for
> example. To process anything is taking too long. I know there has been a
> discussion on ARMS hardware, but that seems a few years away. So right now,
> what would you recommend? I plan to partition the hard drive to handle
> ArcGIS as well. I do not think I can afford a dream machine like Mac Pro,
> though. Is a Mac mini something that you guys use and recommend?
> Best wishes,
> Reiko Matsuda Goodwin
> ComoƩ Monkey Project <https://www.facebook.com/ComoeMonkeyProject/>
> Guenon Conservation Community
> <http://facebook.com/GuenonConservationCommunity/>
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200909/1787e390/attachment.html>
