[Qgis-user] GeoJSON coordinate precision
Christoph Jung
jagodki.cj at gmail.com
Tue Sep 15 11:19:57 PDT 2020
Unbelievable how I could not recognise this setting in the export window. Again a great example that the human in front of the pc is mostly the main problem :)
Thank you, Werner, for your help.
Christoph
> Am 15.09.2020 um 13:57 schrieb Werner Macho <werner.macho at gmail.com>:
> Hi Christoph,
> back in front of my PC there is room for further explanation ;)
> if you right click on the layer to export and go to "Export" -> "Save
> Features As" the Export window opens ..
> If you scroll down a bit there are "Layer Options" - and within the
> Layer Options (depending to which format you want to export, but you
> said GeoJSON - and within GeoJSON I just checked that the option is
> really there) there is the "COORDINATE_PRECISION" Option in the first
> line (followed by RFC7946 and WRITE_BBOX).
> Default should be 15 as precision ..
> Hope this helps
> regards
> Werner
>> On Tue, Sep 15, 2020 at 1:51 PM Christoph Jung <jagodki.cj at gmail.com> wrote:
>> Hello Werner,
>> Thank you for your response. I looked for a parameter like coordinate_precision, but I could not find anything similar in the export dialogue (for GeoJSON), in the application options also not.
>> Christoph
>>>> Am 15.09.2020 um 11:40 schrieb Werner Macho <werner.macho at gmail.com>:
