[Qgis-user] pdf generation not working
Andreas Neumann
a.neumann at carto.net
Thu Sep 17 04:06:22 PDT 2020
Most likely, you are not an runninng an X-Server and/or haven't
configured the display environment variable properly.
See
https://docs.qgis.org/testing/en/docs/server_manual/getting_started.html#xvfb
[1]for more information.
Greetings,
Andreas
On 2020-09-17 12:35, Davide wrote:
> Hi,
> we are using the qgis web client 2, but when we request the pdf, then an error occours. Debugging the request we see that the qgis server, that uses qgis_mapserv.fcgi return error 500 (tested directly with curl).
> We have tried to enable logging like
> QGIS_SERVER_LOG_FILE
> QGIS_SERVER_LOG_LEVEL
> but logs are always empty.
> With this situation we can't understand where the problem is.
> Any suggestion about how to enable logging and/or why the pdf can return and error 500 ?
> Thanks in advance for any help!
> Davide Montesin
> Italy
> Qgis-user mailing list
Links:
[1]
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200917/578c7a1a/attachment.html>
