[Qgis-user] automatic data entry
David Greenewalt
dlg at sover.net
Thu Sep 17 06:06:44 PDT 2020
I typed "closest" into the search box (bottom left of screen), and saw
the processing algorithm "Join Attributes By Nearest" . It may be
worth looking into.
Thanks,
David
On 9/17/2020 7:07 AM, Nicolas Cadieux wrote:
> Hi,
> You could make a 25m buffer and then use “join attributes by location”
> fond in processing.
> Once the information is in the buffer object table, start again with
> the buffer and your line, point and polygons.
> https://www.qgistutorials.com/en/docs/performing_spatial_queries.html?highlight=buffer
> https://www.qgistutorials.com/en/docs/3/performing_spatial_joins.html
> Nicolas Cadieux
>> Le 17 sept. 2020 à 04:23, FVHGmail <ferrolvh at gmail.com> a écrit :
>> Hello ,
>> I use QGIS 3.14 and I want to arrange when I draw a line , point or
>> area that the fields City and Street can be are filled with the
>> closest City and Street-name out of OpenStreetMap . In a range of
>> 25 Meter . The marking I draw are always on a street or bicycle path.
>> Maybe an easy question but I am new in the use of QGIS so I can use
>> a little help the experts .
>> Kind regards
>> Ferrol
>> Sent from Mail <https://go.microsoft.com/fwlink/?LinkId=550986> for
>> Windows 10
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200917/9fea468e/attachment.html>
