[Qgis-user] Grass Processing Tools fail in QGIS LTR, PR & Nightly Builds on MacOS
Mr. Stace D Maples
stacemaples at stanford.edu
Thu Sep 17 10:44:36 PDT 2020
Confirmed GRASS fixed in the nightly! Thanks Lutra and Peter Petrik!
In F,L&T,
Stace Maples
Geospatial Manager
Stanford Geospatial Center
@mapninja
G+, Skype, Hangout: stacey.maples
214.641.0920
Wednesdays 3-5pm on http://KZSULive.stanford.edu
Find GeoData: https://earthworks.stanford.edu<https://earthworks.stanford.edu/>
Get GeoHelp: https://gis.stanford.edu/
stanfordgis Listserv: https://mailman.stanford.edu/mailman/listinfo/stanfordgis
"I have a map of the United States... actual size.
It says, "Scale: 1 mile = 1 mile."
I spent last summer folding it."
-Steven Wright-
From: Qgis-user <qgis-user-bounces at lists.osgeo.org> on behalf of "Mr. Stace D Maples" <stacemaples at stanford.edu>
Date: Wednesday, September 16, 2020 at 4:05 PM
To: qgis-user <qgis-user at lists.osgeo.org>
Subject: [Qgis-user] Grass Processing Tools fail in QGIS LTR, PR & Nightly Builds on MacOS
Anyone have any luck getting grass tools to work on MacOS? This problem never seems to go away. Any ideas area appreciated. I’ve got 75 students in a Fundamentals course starting to work on their assignments, next week, and no one can get QGIS to work properly. Windows users are having issues, too, but I haven’t even gotten to them, yet. Here’s my write-up from the last 3 hours of deleting profiles and reinstalling 3 versions on Catalina 10.15.6:
I seem to be having the same issue, an issue I've seen many times in the past. My routine for testing a new installation of QGIS is to add the QuickMapPlugin, Create random points and then use v.voronoi on those points to test the historically finicky GRASS processing tools.
1. Deleted user profile for all QGIS users and uninstalled previous apps
2. Download Latest Release: qgis-macos-pr.dmg and install
3. Open QGIS with new empty doc
FYI, I don't think the next 2 steps have anything to do with the issue, but adding them full acccounting:
4. Install QuickMapServices Plugin, add contrib services
5. Add Stamen Toner Lite
6. Run "Random points in extent" from Processing Panel
a. Use Canvas Extent
b. 10 Points
c. Target CRS: 3857 (also tried outputing to 4326, same results)
d. [Create temporary layer]
7. Runs fine, produces expected random points
8. Run v.voronoi tool on resulting random points
a. Use Map Canvas Extent
b. All else=default
c. Save to temp
9. Fails with the error, below
10. ReRun with option to save random points to point.shp produces the same error.
11. Identical results for 40+ students,using LTR
12. Repeat exact steps with fresh LTR, including deleting the User Profile
13. same results, exactly.
14. Nightly Build doesn't load the GRASS Provider, at all.
Log WIndow:
`QGIS version: 3.14.16-Pi
QGIS code revision: a235a14<https://github.com/qgis/QGIS/commit/a235a149f0864a22dc99fed5f6267e2b586b8e57>
Qt version: 5.12.3
GDAL version: 2.4.1
GEOS version: 3.7.2-CAPI-1.11.2 b55d2125
PROJ version: Rel. 5.2.0, September 15th, 2018
Processing algorithm…
Algorithm 'v.voronoi' starting…
Input parameters:
{ '-l' : False, '-t' : False, 'GRASS_MIN_AREA_PARAMETER' : 0.0001, 'GRASS_OUTPUT_TYPE_PARAMETER' : 0, 'GRASS_REGION_PARAMETER' : '-13670428.191800000,-13586035.687300000,4532539.747800000,4571278.579000000 [EPSG:3857]', 'GRASS_SNAP_TOLERANCE_PARAMETER' : -1, 'GRASS_VECTOR_DSCO' : '', 'GRASS_VECTOR_EXPORT_NOCAT' : False, 'GRASS_VECTOR_LCO' : '', 'input' : '/Users/maples/Downloads/points.shp|layername=points', 'output' : 'TEMPORARY_OUTPUT' }
g.proj -c proj4="+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null<https://github.com/null> +wktext +no_defs"
v.in.ogr min_area=0.0001 snap=-1.0 input="/Users/maples/Downloads/points.shp" layer="points" output="vector_5f627ae75a6d96" --overwrite -o
g.region n=4571278.579 s=4532539.7478 e=-13586035.6873 w=-13670428.1918
v.voronoi input=vector_5f627ae75a6d96 output=output0fc09ffb9e94472baedcf2a353550eca --overwrite
v.out.ogr type="auto" input="output0fc09ffb9e94472baedcf2a353550eca" output="/private/var/folders/f3/0prmkq7962795yfpwsmvh2100000gq/T/processing_xxaYqK/a0d0a2d2844c493babe4c52273dc5a59/output.gpkg" format="GPKG" --overwrite
Starting GRASS GIS...
Executing </private/var/folders/f3/0prmkq7962795yfpwsmvh2100000gq/T/processing_xxaYqK/grassdata/grass_batch_job.sh> ...
dyld: Symbol not found: _iconv
Referenced from: /usr/lib/libarchive.2.dylib
Expected in: /Applications/QGIS3.14.app/Contents/Resources/grass7/lib/libiconv.2.dylib
in /usr/lib/libarchive.2.dylib
/private/var/folders/f3/0prmkq7962795yfpwsmvh2100000gq/T/processing_xxaYqK/grassdata/grass_batch_job.sh: line 2: 3039 Abort trap: 6 g.proj -c proj4="+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null<https://github.com/null> +wktext +no_defs"
/private/var/folders/f3/0prmkq7962795yfpwsmvh2100000gq/T/processing_xxaYqK/grassdata/grass_batch_job.sh: line 3: 3040 Abort trap: 6 v.in.ogr min_area=0.0001 snap=-1.0 input="/Users/maples/Downloads/points.shp" layer="points" output="vector_5f627ae75a6d96" --overwrite -o
/private/var/folders/f3/0prmkq7962795yfpwsmvh2100000gq/T/processing_xxaYqK/grassdata/grass_batch_job.sh: line 4: 3041 Abort trap: 6 g.region n=4571278.579 s=4532539.7478 e=-13586035.6873 w=-13670428.1918
/private/var/folders/f3/0prmkq7962795yfpwsmvh2100000gq/T/processing_xxaYqK/grassdata/grass_batch_job.sh: line 5: 3042 Abort trap: 6 v.voronoi input=vector_5f627ae75a6d96 output=output0fc09ffb9e94472baedcf2a353550eca --overwrite
/private/var/folders/f3/0prmkq7962795yfpwsmvh2100000gq/T/processing_xxaYqK/grassdata/grass_batch_job.sh: line 6: 3043 Abort trap: 6 v.out.ogr type="auto" input="output0fc09ffb9e94472baedcf2a353550eca" output="/private/var/folders/f3/0prmkq7962795yfpwsmvh2100000gq/T/processing_xxaYqK/a0d0a2d2844c493babe4c52273dc5a59/output.gpkg" format="GPKG" --overwrite
Execution of </private/var/folders/f3/0prmkq7962795yfpwsmvh2100000gq/T/processing_xxaYqK/grassdata/grass_batch_job.sh> finished.
File "/Applications/QGIS3.14.app/Contents/Resources/grass7/bin/_grass76", line 2207, in
main()
File "/Applications/QGIS3.14.app/Contents/Resources/grass7/bin/_grass76", line 2155, in main
clean_all()
File "/Applications/QGIS3.14.app/Contents/Resources/grass7/bin/_grass76", line 1789, in clean_all
gsetup.clean_default_db()
File "/Applications/QGIS3.14.app/Contents/Resources/grass7/etc/python/grass/script/setup.py", line 220, in clean_default_db
conn = gdb.db_connection()
File "/Applications/QGIS3.14.app/Contents/Resources/grass7/etc/python/grass/script/db.py", line 108, in db_connection
nuldev = file(os.devnull, 'w')
NameError: name 'file' is not defined
/Applications/QGIS3.14.app/Contents/Resources/grass7/grass76.sh: line 20: /private/var/folders/f3/0prmkq7962795yfpwsmvh2100000gq/T/processing_xxaYqK/grassdata/temp_location/PERMANENT: is a directory
Execution completed in 1.06 seconds
Results:
{'output': <QgsProcessingOutputLayerDefinition {'sink':TEMPORARY_OUTPUT, 'createOptions': {'fileEncoding': 'System'}}>}
Loading resulting layers
The following layers were not correctly generated.
• /private/var/folders/f3/0prmkq7962795yfpwsmvh2100000gq/T/processing_xxaYqK/a0d0a2d2844c493babe4c52273dc5a59/output.gpkg
You can check the 'Log Messages Panel' in QGIS main window to find more information about the execution of the algorithm.`
Grass7 Messages:
2020-09-16T13:36:32 INFO processInputs end. Commands: ['g.proj -c proj4="+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +wktext +no_defs"', 'v.in.ogr min_area=0.0001 snap=-1.0 input="/private/var/folders/f3/0prmkq7962795yfpwsmvh2100000gq/T/processing_xxaYqK/08af800894524bfab7d0246fa9cfa686/input.shp" output="vector_5f627750a89682" --overwrite -o', 'g.region n=4571278.579 s=4532539.7478 e=-13603929.6588 w=-13652534.2203'] 2020-09-16T13:36:32 INFO processCommands end. Commands: ['g.proj -c proj4="+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +wktext +no_defs"', 'v.in.ogr min_area=0.0001 snap=-1.0 input="/private/var/folders/f3/0prmkq7962795yfpwsmvh2100000gq/T/processing_xxaYqK/08af800894524bfab7d0246fa9cfa686/input.shp" output="vector_5f627750a89682" --overwrite -o', 'g.region n=4571278.579 s=4532539.7478 e=-13603929.6588 w=-13652534.2203', 'v.voronoi input=vector_5f627750a89682 output=output0a0d63c243fe4fe7ba108fc071fb92e3 --overwrite'] 2020-09-16T13:37:14 INFO processInputs end. Commands: ['g.proj -c proj4="+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +wktext +no_defs"', 'v.in.ogr min_area=0.0001 snap=-1.0 input="/private/var/folders/f3/0prmkq7962795yfpwsmvh2100000gq/T/processing_xxaYqK/3e6d8b4161c148319a28b77258238e5f/input.shp" output="vector_5f62777a579b03" --overwrite -o', 'g.region n=4571278.579 s=4532539.7478 e=-13603929.6588 w=-13652534.2203'] 2020-09-16T13:37:14 INFO processCommands end. Commands: ['g.proj -c proj4="+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +wktext +no_defs"', 'v.in.ogr min_area=0.0001 snap=-1.0 input="/private/var/folders/f3/0prmkq7962795yfpwsmvh2100000gq/T/processing_xxaYqK/3e6d8b4161c148319a28b77258238e5f/input.shp" output="vector_5f62777a579b03" --overwrite -o', 'g.region n=4571278.579 s=4532539.7478 e=-13603929.6588 w=-13652534.2203', 'v.voronoi input=vector_5f62777a579b03 output=outpute794dfeeeea144df98a90b7a07128ca0 --overwrite'] 2020-09-16T13:38:55 INFO processInputs end. Commands: ['g.proj -c proj4="+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +wktext +no_defs"', 'v.in.ogr min_area=0.0001 snap=-1.0 input="/private/var/folders/f3/0prmkq7962795yfpwsmvh2100000gq/T/processing_xxaYqK/2c92d7fff8934dc0b3e37199fe83a09c/input.shp" output="vector_5f6277dfbe5304" --overwrite -o', 'g.region n=4570531.891981606 s=4534907.978609399 e=-13613607.067557963 w=-13651848.786443522'] 2020-09-16T13:38:55 INFO processCommands end. Commands: ['g.proj -c proj4="+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +wktext +no_defs"', 'v.in.ogr min_area=0.0001 snap=-1.0 input="/private/var/folders/f3/0prmkq7962795yfpwsmvh2100000gq/T/processing_xxaYqK/2c92d7fff8934dc0b3e37199fe83a09c/input.shp" output="vector_5f6277dfbe5304" --overwrite -o', 'g.region n=4570531.891981606 s=4534907.978609399 e=-13613607.067557963 w=-13651848.786443522', 'v.voronoi input=vector_5f6277dfbe5304 output=output9a09588a79b54d9ea768c6f2b689c702 --overwrite'] 2020-09-16T13:39:58 INFO processInputs end. Commands: ['g.proj -c proj4="+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +wktext +no_defs"', 'v.in.ogr min_area=0.0001 snap=-1.0 input="/private/var/folders/f3/0prmkq7962795yfpwsmvh2100000gq/T/processing_xxaYqK/5b575cc50fc849a1bb97003b5f78f42b/input.shp" output="vector_5f62781edb4255" --overwrite -o', 'g.region n=4571278.579 s=4532539.7478 e=-13586035.6873 w=-13670428.1918'] 2020-09-16T13:39:58 INFO processCommands end. Commands: ['g.proj -c proj4="+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +wktext +no_defs"', 'v.in.ogr min_area=0.0001 snap=-1.0 input="/private/var/folders/f3/0prmkq7962795yfpwsmvh2100000gq/T/processing_xxaYqK/5b575cc50fc849a1bb97003b5f78f42b/input.shp" output="vector_5f62781edb4255" --overwrite -o', 'g.region n=4571278.579 s=4532539.7478 e=-13586035.6873 w=-13670428.1918', 'v.voronoi input=vector_5f62781edb4255 output=output03206a43e4b742dbbfd883da361be4bc --overwrite'] 2020-09-16T13:51:51 INFO processInputs end. Commands: ['g.proj -c proj4="+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +wktext +no_defs"', 'v.in.ogr min_area=0.0001 snap=-1.0 input="/Users/maples/Downloads/points.shp" layer="points" output="vector_5f627ae75a6d96" --overwrite -o', 'g.region n=4571278.579 s=4532539.7478 e=-13586035.6873 w=-13670428.1918'] 2020-09-16T13:51:51 INFO processCommands end. Commands: ['g.proj -c proj4="+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +wktext +no_defs"', 'v.in.ogr min_area=0.0001 snap=-1.0 input="/Users/maples/Downloads/points.shp" layer="points" output="vector_5f627ae75a6d96" --overwrite -o', 'g.region n=4571278.579 s=4532539.7478 e=-13586035.6873 w=-13670428.1918', 'v.voronoi input=vector_5f627ae75a6d96 output=output0fc09ffb9e94472baedcf2a353550eca --overwrite'] 2020-09-16T13:53:25 INFO processInputs end. Commands: ['g.proj -c proj4="+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +wktext +no_defs"', 'v.in.ogr min_area=0.0001 snap=-1.0 input="/Users/maples/Downloads/points.shp" layer="points" output="vector_5f627b452c9c37" --overwrite -o', 'g.region n=4571278.579 s=4532539.7478 e=-13586035.6873 w=-13670428.1918'] 2020-09-16T13:53:25 INFO processCommands end. Commands: ['g.proj -c proj4="+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +wktext +no_defs"', 'v.in.ogr min_area=0.0001 snap=-1.0 input="/Users/maples/Downloads/points.shp" layer="points" output="vector_5f627b452c9c37" --overwrite -o', 'g.region n=4571278.579 s=4532539.7478 e=-13586035.6873 w=-13670428.1918', 'v.voronoi input=vector_5f627b452c9c37 output=outpute37f6908fba34e188ad9ccedb42a9b3a --overwrite']
In F,L&T,
Stace Maples
Geospatial Manager
@mapninja
214.641.0920
-Steven Wright-
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200917/9dc996c7/attachment-0001.html>
