[Qgis-user] automatic data entry
Donal Hunt donal.hunt at gmail.com
Fri Sep 18 06:17:05 PDT 2020
Can you expand on your answer for the benefit of others in the future?
Thanks!
On Fri, 18 Sep 2020 at 14:11, FVHGmail <ferrolvh at gmail.com> wrote:
> Thanks all , solved
> Sent from Mail <https://go.microsoft.com/fwlink/?LinkId=550986> for
> Windows 10
> *From: *David Greenewalt <dlg at sover.net>
> *Sent: *Thursday, 17 September 2020 16:07
> *To: *qgis-user at lists.osgeo.org
> *Subject: *Re: [Qgis-user] automatic data entry
> I typed "closest" into the search box (bottom left of screen), and saw the
> processing algorithm  "Join Attributes By Nearest" .  It may be worth
> looking into.
> Thanks,
> David
> On 9/17/2020 7:07 AM, Nicolas Cadieux wrote:
> Hi,
> You could make a 25m buffer and then use “join attributes by location”
> fond in processing.
> Once the information is in the buffer object table, start again with the
> buffer and your line, point and polygons.
> https://www.qgistutorials.com/en/docs/performing_spatial_queries.html?highlight=buffer
> https://www.qgistutorials.com/en/docs/3/performing_spatial_joins.html
> Nicolas Cadieux
> Le 17 sept. 2020 à 04:23, FVHGmail <ferrolvh at gmail.com>
> <ferrolvh at gmail.com> a écrit :
> Hello ,
> I use QGIS 3.14  and I want to arrange when I draw a line , point or area
> that the fields  City and Street can be are filled with the closest  City
> and Street-name out of OpenStreetMap .   In a range of 25 Meter  . The
> marking I draw are always on a street or bicycle path.
> Maybe an easy question but I am new in the use of QGIS  so I can use a
> little help the experts .
> Kind regards
> Ferrol
> Windows 10
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200918/efe30744/attachment.html>
