[Qgis-user] How to create one new string-value from many other string-values?
Aron Gergely
aron.gergely at rasterra.nl
Wed Sep 23 03:22:44 PDT 2020
By accident I did not reply via the list :( see my suggested solution below
On 23/09/2020 10:10, Aron Gergely wrote:
> Hi Jan,
> You would be able to solve this with the 'Aggregate' tool:
> https://docs.qgis.org/testing/en/docs/user_manual/processing_algs/qgis/vectorgeometry.html#qgisaggregate
> It groups rows of data according to an expression (just per ID value
> in your case)
> and can aggregate the attribute field values via aggregate functions.
> For your field containing all those street name letters, you could
> then select the 'concatenate' function.
> You may have to look into sorting your rows if the letters are not
> concatenated in the right order.
> The tool also supports expressions on the input fields.
> Good luck!
> Aron
> On 23/09/2020 09:04, Jan.Rutha at STADT-KOELN.DE wrote:
>> hi there,
>> I got a table with a content for streetnames. For example the street
>> “Mainstreet” ist separated in
>> 10 different rows of data (one dataset for each letter in the word
>> “Mainstreet”).
>> I would like to merge these 10 datasets to one dataset. All those
>> datasets have one ID – so they qgis should
>> be able to search for the same Id and create a new textstring with
>> all the leters.
>> I don’t know how to practicly implement my idea in QGIS. Does anyone
>> have an idea for me?
>> Thanks a lot and I wish you all a good day!
>> Jan R.
>> Monatlich aktuelle Informationen Ihrer Stadtverwaltung in unserem
>> Newsletter! Newsletter Anmeldung
>> <https://www.stadt-koeln.de/service/onlinedienste/newsletter-anmeldung?para=allgemein>
>> <https://www.bundesregierung.de/breg-de/themen/corona-warn-app>
>> https://www.stadt-koeln.de/images/footer_wahlhelferaufruf2020.jpg
>> <http://www.wahlhelfer.koeln/>
>> Qgis-user mailing list
>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Email Signature Kind Regards,
> Aron Gergely
> +31 (0) 6 38 70 97 66
> *Rasterra* | www.rasterra.nl <https://www.rasterra.nl>
Aron Gergely
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200923/76b4ae5f/attachment.html>
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200923/76b4ae5f/attachment.vcf>
