[Qgis-user] Reliable geocoding alternative?
Nicolas Cadieux
njacadieux.gitlab at gmail.com
Wed Sep 23 07:20:18 PDT 2020
Do you have coordinates (x,y) in that csv? You can generate the geometries from that. If not, you will need to find a database for that. What were you planing on using for the geospatial info?
Nicolas Cadieux
> Le 23 sept. 2020 à 10:17, Erich Purpur <epurpur at gmail.com> a écrit :
> Thank you again for your response. I understand what you suggest but it won't work in this case unfortunately.
> I only have a .csv file, which has an address and all the other information too. There is no other layer.
> -Erich
>> On Wed, Sep 23, 2020 at 10:12 AM Nicolas Cadieux <njacadieux.gitlab at gmail.com> wrote:
>> Hi,
>> To do this, you need two files. If they are csv, you can use that. If you are limited in what you can do, just save a geopackage. You will need one file with the addresses (that you have) and one file, or a data base with the georeferenced information. Do you have that? If not what where you planing to use to find the geographic positions of the objects?
>> A csv is a vector layer if it’s georeferenced or a database if it’s not. You may be limited in what you can do but export it to a for at that QGIS can write to like geopackage or SpatiaLite which is the same thing but with not spatial info.
>> Nicolas Cadieux
>>> Le 23 sept. 2020 à 08:52, Erich Purpur <epurpur at gmail.com> a écrit :
>>> Hi Nicolas-
>>> The issue is that I have data in a .csv file. Each row has an address. Both the 'join attributes by location' and 'join attributes by field value' tool specify that it joins vector layers. But I don't have a vector layer.
>>> -Erich
>>>> On Tue, Sep 22, 2020 at 7:41 PM Nicolas Cadieux <njacadieux.gitlab at gmail.com> wrote:
>>>> Hi,
>>>> Why not just use "Join Attributes by Location" or "Join Attributes by Field Value" in Processing? If you have inconsistent results, I would look at your data base. Are you using unique fields? Do you have duplicate shapes or shape collections (MultiPoints, Mulit...)? What method are you using? intersects, within... ?
>>>> Nicolas
>>>> On 2020-09-22 7:19 p.m., Erich Purpur wrote:
>>>>> Hi all-
>>>>> Geocoding is the one process I am still doing in ArcPro. Most of the QGIS geocoding tutorials I have found recommend using the Geocoding tool in MMQGIS but I have really struggled to get consistent results.
>>>>> Does anyone have an alternative Geocoding plugin or other tool they use? It doesn't have to be within QGIS, an external tool would be fine.
>>>>> Thank you,
>>>>> Erich Purpur
>>>>> _______________________________________________
>>>>> Qgis-user mailing list
>>>>> Qgis-user at lists.osgeo.org
>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200923/060c1a70/attachment.html>
