[Qgis-user] PyQGIS: wipe all xyz connections
1520 gis juliermeopensourcedeveloper at gmail.com
Wed Sep 23 10:45:03 PDT 2020
Hi Erich Purpur,
I am a Python coding beginner and made some changes according to your
reply. I have a XYZ connection for OpenStreetMap. But after hitting the
button wipeAllConnectionsXyz in a QGIS Plugin, I did not get any error
message, but the OSM connection was not removed. Find the code below:
def removeAllConnectionsXYZ(self):
s = QSettings()
xyz = 'qgis/connections-xyz'
groupsXYZ = s.childGroups()
for group in groupsXYZ:
s.beginGroup(xyz)
s.remove("")
s.endGroup()
self.dlg.wipeAllConnectionsXyz.clicked.connect(
self.removeAllConnectionsXYZ)
# Kind regards
# Julierme
On Wed, Sep 23, 2020 at 1:54 PM Erich Purpur <epurpur at gmail.com> wrote:
> Is this regarding the following stackoverflow thread?
> https://gis.stackexchange.com/questions/374808/pyqt5-wipe-xyz-connections
> If so, your error message as you posted it in StackOverflow is:
> for group in getGroupXYZ(self): NameError: name 'getGroupXYZ' is not
> defined
> From what I gather in the code posted in SO, you are trying to iterate
> over getGroupXYZ(), which is a function. This is not an object which holds
> multiple items, which is the purpose of a loop. However, in your
> getGroupXYZ() function, you return an object called groupsXYZ. You should
> loop of the groupsXYZ object, not the function.
> -Erich
> On Wed, Sep 23, 2020 at 11:38 AM 1520 gis <
> juliermeopensourcedeveloper at gmail.com> wrote:
>> Dear all,
>> I am writing a PyQT5 QGIS Plugin to wipe out all xyz connections
>> available in QGS projects.
>> I wrote the code below, but I am not achieving my goal and I did not
>> understand the structure of xyz connections.
>> s = QSettings()
>> s.beginGroup(xyz)
>> s.remove("")
>> s.endGroup()
>> # Any comment will be very appreciated.
>> #Thank you for your time in advance
>> #Julierme
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200923/6518cdd2/attachment.html>
