[Qgis-user] Generate the bearing in the attribute table
carloslda256 at gmail.com
Thu Apr 8 17:12:54 PDT 2021
Hi Yes!
For example this formula gives the azimuth:
azimuth (start_point ($ geometry), end_point ($ geometry))
What I require is the same ... but that you give me the angle not in azimuth,
but in Bearing ...
For example N30 ° 30'25´´E, S20 ° 35E etc
Thanks
CA
[data:image/gif;base64,R0lGODlhAQABAIAAAP///wAAACwAAAAAAQABAAACAkQBADs=3D]El
jue, 8 abr 2021 a las 16:55, David Strip (<qgis-user at stripfamily.net>) escribió:
> are you asking for the bearing between each successive pair of vertices? ie,
the bearing from vertex n to vertex n+1?
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210409/c3d12542/attachment.html>
