[Qgis-user] Generate the bearing in the attribute table
    carlos h
    carloslda256 at gmail.com
    Fri Apr  9 05:21:42 PDT 2021
Hello, I think I made a conceptual error, it is not a polygon, but a
polyline that has "n" number of vertices.
https://ibb.co/vsGF22W
I think that when you see the attached image you will understand what I
want, what I want is to generate the bearing in the attribute table.
Thanks
CA
El jue, 8 abr 2021 a las 22:17, chris hermansen (<clhermansen at gmail.com>)
escribió:
> David & list,
> On Thu, Apr 8, 2021, 20:02 David Strip <qgis-user at stripfamily.net> wrote:
>> On 4/8/2021 6:32 PM, chris hermansen wrote:
>> Please correct me if I am wrong but are not the start and end points of a
>> polygon the same?
>> I believe he's referring to the start and end point of each edge.
> As far as I know a polygon only has one edge, unless it has interior
> holes. That's what the $geometry would be, anyway.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210409/ef356733/attachment.html>
