[Qgis-user] Something to use found - RE: How to "Affine Transform" and rotate at a given point
Jeff Sonnentag
jsonnentag at llenviroinc.com
Fri Apr 9 10:39:24 PDT 2021
Something to use was found based on this:
https://gis.stackexchange.com/questions/322262/rotating-shape-around-defined-point-instead-of-centroid-in-qgis
It's handy to know you can hold CTRL and click to set the point rotation occurs around.
From: Qgis-user <qgis-user-bounces at lists.osgeo.org> On Behalf Of Jeff Sonnentag
Sent: Friday, April 9, 2021 10:21 AM
To: qgis-user <qgis-user at lists.osgeo.org>
Subject: [Qgis-user] How to "Affine Transform" and rotate at a given point
So basically we have some "engineering" somebody just made up their own coordinate system for that arrived as a DWG and was converted to a DXF in order to get it to appear in QGIS (3.16.5). At first I thought it was in feet but aligning a corner showed that wasn't right and it wasn't in inches either.
After figuring out and setting a Scale Factor and then re-aligning to a corner things are OK except for a rotation that needs to occur. It needs to occur around the corner match point. Is that even possible in QGIS? It is all built into the transform function/tool in ArcMap so all you have to do is set where X and Y are supposed to come from and their final destination and the rotation occurs around that reference point. Is there a way to do that in QGIS?
Setting a rotation "around the z-axis" sends things off into the wild blue yonder. . . .
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210409/f295711f/attachment.html>
