[Qgis-user] gml file on sample data won't load
Thayer Young
thayeray at yahoo.com
Sat Apr 10 20:10:43 PDT 2021
Hi Larry,
You may not have downloaded the gml file, instead you probably have a Github webpage of the gml code. If you do the following you can turn it into GML:
1) change the file ending from .gml to .html 2) open the file in a web browser 3) copy and paste the xml (from lines 1 to 149) into a text editor, like gedit or vim. FYI, GML is a type of XML. Line 1: <?xml version="1.0" encoding="utf-8" ?> Line 149: </ogr:FeatureCollection>4) save the pasted text to a file named: lakes.gml5) try opening it again in QGIS.
If that does not work, you can go to this address: https://github.com/qgis/QGIS-Sample-Data/blob/master/qgis_sample_data/gml/lakes.gmland start from 3) above.
-Thayer
On Saturday, April 10, 2021, 03:00:34 PM EDT, qgis-user-request at lists.osgeo.org <qgis-user-request at lists.osgeo.org> wrote:
Date: Sat, 10 Apr 2021 15:50:08 +0000
From: Larry Johnson <larry.johnson at cobbcountycourier.com>
To: "qgis-user at lists.osgeo.org" <qgis-user at lists.osgeo.org>
Subject: [Qgis-user] gml file on sample data won't load
Message-ID:
<MW3PR18MB3593312FA3E81016DD415FF8FD729 at MW3PR18MB3593.namprd18.prod.outlook.com>
Content-Type: text/plain; charset="utf-8"
I'm trying to systematically learn qgis starting with the sample Alaska lakes data, and hit a snag immediately.
The lakes.gml file doesn't load.
I've did a web search and found a few references to the issue, but no resolution.
The bug report page on github had one instance of the problem which was closed for "lack of feedback."
I saw no search feature on the archives here, so I don't know if this problem has been addressed in the list.
I'm running QGIS Desktop 3.18 on Fedora 33 on a Dell Inspiron laptop.
If someone could point me to either an answer or a starting point to explore the problem I'd appreciate it.
?Larry Johnson
Editor and Publisher
Cobb County Courier
404-664-2034
http://cobbcountycourier.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210410/4b74f7d8/attachment-0001.html>
Message: 3
Date: Sat, 10 Apr 2021 12:54:26 -0500
From: L.J. Mart?nez M. <martinez09186 at gmail.com>
Subject: [Qgis-user] Problem to display raster
Message-ID:
<CACfneMC_F20__Exu3icC5wQAnD+HLPxiO5_-Ug+SK_yuyy6_ww at mail.gmail.com>
Dear users, i am using versi?n qgis 3.18, when i try to display a raster
file to show clases (group values by classes) usign Singleband pseudocolor,
the image does not show the clases and remains unchanged.
If i use reclassify values (simple) and error appears.
When i use past versions these problems does not ocur.
Best regards
Luis
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210410/547c45e1/attachment-0001.html>
Subject: Digest Footer
Qgis-user mailing list
Qgis-user at lists.osgeo.org
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
End of Qgis-user Digest, Vol 182, Issue 14
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210411/89940b8d/attachment-0001.html>
