[Qgis-user] Issue with How Selected Features are Displayed When Overlapping
Thayer Young
thayeray at yahoo.com
Fri Apr 16 07:25:18 PDT 2021
Hi Calvin,
I also agree this is a pain.
I think the official response to this problem is to right click on the feature in the attribute table and select "Flash Feature" which flashes the feature in red. I usually use transparency when things overlap. If that is not good enough alone, you can combine it with rule based symbology. For example, everything is opaque until something is selected, then only the selected feature is opaque and the rest are for example 30% opaque:
100% opacity rule: (is_selected() AND num_selected( ) > 0) OR num_selected() = 030% opacity rule: not is_selected() AND num_selected( ) > 0
But this won't work if you have different layers that are obscuring each other.
-Thayer
>Date: Thu, 15 Apr 2021 13:38:39 -0400
>From: C Hamilton <adenaculture at gmail.com>
>To: Nicolas Cadieux <njacadieux.gitlab at gmail.com>
>Cc: qgis-user <qgis-user at lists.osgeo.org>, qgis-developer
<qgis-developer at lists.osgeo.org>
>Subject: Re: [Qgis-user] Issue with How Selected Features are
>Message-ID:
<CABPxTTpS_5S77c8zDQ6M8w-JSiZhb6JF638Q4-QS2B0egs=Arw at mail.gmail.com>
>Content-Type: text/plain; charset="utf-8"
>If there is a large cluster of points obscuring the selected point, even
>that method will not work.
>Has there been any interest in changing this behavior in QGIS?
On Thu, Apr 15, 2021 at 11:46 AM Nicolas Cadieux <
njacadieux.gitlab at gmail.com> wrote:
> Hi,
> Indeed... I usually select a thicker line for feature that are below. This
> way, I can see the selection even if it?s hidden.
> Nicolas Cadieux
> https://gitlab.com/njacadieux
> Le 15 avr. 2021 ? 11:14, C Hamilton <adenaculture at gmail.com> a ?crit :
> I have a user complaint with QGIS who explained that when point features
> overlap and one is selected from the attribute table but is underneath
> other features, you cannot see it highlighted because it is covered by
> other points. Is there any way to have it show that there is a highlighted
> feature there even though it is underneath non-highlighted features? In
> ArcMap the highlights are always shown on the top level of the canvas even
> if they are covered by non-highlighted features.
> I tested this in QGIS and the user was correct.
> Thanks,
> Calvin
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210415/9ca88664/attachment-0001.html>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210416/ea07fb91/attachment.html>
