[Qgis-user] Cannot add cloud optimised GeoTIFF (COG) as raster layer
jratike80
jukka.rahkonen at maanmittauslaitos.fi
Mon Apr 19 01:58:22 PDT 2021
Hi Andrea,
Setting the GDAL_HTTP_PROXY env variable solved my problem. Should I file a
ticket about this or is there some use case where the proxy that is
configured in general settings should not be applied?
-Jukka Rahkonen-
Andrea Giudiceandrea wrote
> jcabieces wrote
>> It works for me with current QGIS master if I paste this exact url in URI
>> with HTTP/HTTPS/FTP
>> type : http://latuviitta.kapsi.fi/data/dem10m/dem10.tif
> Hi,
> I can also add and display the raster layer in QGIS adding it using Data
> Source Manager | Raster as:
> Source Type: Protocol: HTTP(S)...
> URI: http://latuviitta.kapsi.fi/data/dem10m/dem10.tif
> OR
> Source Type: File
> Raster dataset(s):
> /vsicurl/http://latuviitta.kapsi.fi/data/dem10m/dem10.tif
> Anyway, if the problem is the presence of a proxy, maybe the relevant
> GDAL_*PROXY env vars should be set.
> See
> https://gdal.org/user/virtual_file_systems.html#vsicurl-http-https-ftp-files-random-access
> and
> https://gdal.org/user/configoptions.html#list-of-configuration-options-and-where-they-apply
> Regards.
> Andrea
> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
> Qgis-user mailing list
> Qgis-user at .osgeo
