[Qgis-user] Adding a map as a background layer in QGIS
Nicolas Cadieux njacadieux.gitlab at gmail.com
Tue Apr 20 16:13:24 PDT 2021
Do you have the school coordinates?  I see you have access to a csv file
with an id number and a school name.  If you can match that with you own
data, then you can certainly do it.  I would simply contact the web
site.  They can probably give you the georeferenced datasets.
Nicolas
On 2021-04-20 9:28 a.m., krishna Ayyala wrote:
> Hello,
> I have the following map. Is it possible to add this school status map
> as a background map in QGIS? I want to add this Alberta's School
> district map on top of the openstreet map in QGIS.
> Regards.
> https://www.alberta.ca/schools/covid-19-school-status-map.htm
> <https://www.alberta.ca/schools/covid-19-school-status-map.htm>
> Qgis-user mailing list
Nicolas Cadieux
https://gitlab.com/njacadieux
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210420/6635ead3/attachment.html>
