[Qgis-user] python(3) script to calculate latitude longitude values from (ESRI) shape file
wxgis
thinjogger at gmail.com
Wed Apr 21 14:38:42 PDT 2021
Chris and list --
"...you can convert your polygons or lines to points and then again assuming
you have a DEM you can interpolate the elevations at the points." Thanks
for your answer - from your last sentence Chris, does anyone know of some
python code (or snippets will help too) that can take a country boundary
(i.e., the polygon/lines you mention above) and convert to lat/lon? Again,
do you recommend I start with an ESRI .shp file? Can I get country
boundaries from an ESRI .shp file (this is critical for me, i.e., to get
country boundaries) or is there some other type of file I should use?
I do like the idea of getting elevation from a DEM file.
TIA,
Steve
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
