[Qgis-user] Measure distance along line
Sebastian Gutwein
bas at rdgland.com
Thu Apr 29 10:36:26 PDT 2021
Jérémie,
That does sound like a cool feature.
The work around I would use is:
- Create a Line Scratch Layer
- Trace the path of interest (using the automagic trace feature in
snapping)
- Get the derived length by using the identify tool.
-Bas
On Thu, Apr 29, 2021 at 8:49 AM Prud'homme Jérémie <p.jeremie at gmail.com>
wrote:
> Hi,
> Thanks, I didn't thought about this tool but it can do the job.
> Having the ability to follow the line in the measure tool would be simpler
> for QGIS beginners, though.
> BR,
> Jérémie.
> Le jeu. 29 avr. 2021 à 14:03, Ujaval Gandhi <ujaval at spatialthoughts.com>
> a écrit :
>> The closest I can think of is to use the 'Shortest path (point-to-point)'
>> tool from the Processing Toolbox. It will allow you to select 2 points on
>> your line layer and give you an output line with the distance along the
>> line as an attribute/
>> [image: Logo] <https://spatialthoughts.com/>
>> Ujaval Gandhi
>> Spatial Thoughts
>> mobile: +91-8095684687
>> email: ujaval at spatialthoughts.com
>> [image: LinkedIn icon] <https://www.linkedin.com/in/spatialthoughts/> [image:
>> Twitter icon] <https://twitter.com/spatialthoughts>
>> On Thu, Apr 29, 2021 at 5:23 PM Prud'homme Jérémie <p.jeremie at gmail.com>
>> wrote:
>>> Hi,
>>> I am wondering if it's possible to use the Measure distance tool to
>>> measure the distance between two places, following a line.
>>> For example, I click on a first place on the line, I click on a second
>>> place and the tool automagically follow the line.
>>> Same behavior as what we can do with the use of automatic tracing for
>>> geaometrie creations.
>>> BR,
>>> Jérémie.
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210429/7a79955e/attachment.html>
