[Qgis-user] Draw Ellipse/Polygons for areas of maximum concentration
krishna Ayyala
ayyalakrishna at gmail.com
Thu Apr 29 15:24:37 PDT 2021
Chris,
Thanks for the reply. Yes, I did run k-means clustering for 4 clusters. It
is creating a new layer called "clusters". This layer has a field called
Cluster_id, ranging from 1 to 4. But, this method is considering all the
points within the circle. I am looking for the points outside the ellipses
to be omitted (should not be considered). Also K-means clustering is not
generating any polygons/ellipses. We have to identify a cluster based on
the Cluster_ID. I am curious if there is any tool within Qgis that can
produce results similar to the circle with ellipses?
Regards.
On Thu, Apr 29, 2021 at 3:56 PM chris hermansen <clhermansen at gmail.com>
wrote:
> Krishna and list,
> On Thu, Apr 29, 2021 at 2:51 PM krishna Ayyala <ayyalakrishna at gmail.com>
> wrote:
>> Hello,
>> I have a circle in which there are randomly distributed points as below.
>> Each point is a customer.
>> [image: image.png]
>> Is there a tool within QGIS that can automatically generate four polygons
>> or four ellipses such as below. These polygons are the areas of maximum
>> concentration of the customers?
>> [image: image.png]
>> You could try k-means clustering
> https://docs.qgis.org/3.4/en/docs/user_manual/processing_algs/qgis/vectoranalysis.html#k-means-clustering
> Chris Hermansen · clhermansen "at" gmail "dot" com
> C'est ma façon de parler.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210429/97b9a618/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210429/97b9a618/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210429/97b9a618/attachment-0003.png>
