[Qgis-user] Single lines for road network
Wolfgang Meinolf
wmeinolf at bbv-deutschland.de
Sun Aug 1 06:36:18 PDT 2021
Sure. Explode and snap the network, check for duplicates, merge the lines and split with lines with itself. For FTTH approach (should this be relatesd to your previous question) I would not recommend to design anything based on centerlined of roads. For a professional FTTH planning you need to plan nest routes on both sindes of the road. Like here:
[cid:image005.jpg at 01D786EA.F8398F30]
Cheers
Von: Qgis-user <qgis-user-bounces at lists.osgeo.org> Im Auftrag von krishna Ayyala
Gesendet: Samstag, 31. Juli 2021 02:58
An: qgis-user <qgis-user at lists.osgeo.org>
Betreff: [Qgis-user] Single lines for road network
Hello,
I have a huge road network that has double lines such as below. We see such roads mostly for express highways.
[cid:image006.png at 01D786EA.F8398F30]
In the same road network, there are also some streets with single lines such as below.
[cid:image007.png at 01D786EA.F8398F30]
Is it possible to convert the entire road network such that we have only single lines and not double lines such as above. Since the road network is huge, it may not be possible to select manually each segment and run the tools. Is there an automated tool that can do this for the entire network?
Regards.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210801/29ae634c/attachment-0001.html>
Type: image/jpeg
Desc: image005.jpg
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210801/29ae634c/attachment-0001.jpg>
Type: image/png
Desc: image006.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210801/29ae634c/attachment-0002.png>
Type: image/png
Desc: image007.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210801/29ae634c/attachment-0003.png>
Type: application/x-pkcs7-signature
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210801/29ae634c/attachment-0001.bin>
