[Qgis-user] Scalebar segments always go to 2 displayed on units change
Andrea Giudiceandrea
andreaerdna at libero.it
Tue Aug 3 02:32:07 PDT 2021
On Mon, 02 Aug 2021 16:57:01 -0700 Jeff Sonnentag wrote
> Anyway, in a Layout once you have Units set and Segments set to 4 (or anything
> other than 2) and then you change the Units to something else the number of
> Segments still says 4 in that option but the displayed Scalebar only shows 2
> Segments.
Hi Jeff,
when the scalebar unit is changed, then a default size (scale bar 1/5 of
map item width) and a default number of segments for the left and the
right part are applied to the scale bar.
Anyway, as you have reported, the two spinboxes displaying the number of
segments of the scalebar are not properly updated when the scalebar unit
is changed.
So please file a bug report, so somebody (myself too) can fix it.
Regards.
