[Qgis-user] How can I export Vector & Raster layers together to import into mapshaper
Ben Hur Pintor
bnhr.xyz at gmail.com
Thu Aug 12 09:04:32 PDT 2021
Hi Kris,
The OpenStreetMap (OSM) raster layer you mentioned, was this a TIFF file
(something you loaded locally) or was this a basemap loaded as an XYZ tile
layer (i.e. you loaded the OpenStreetMap tile layer found by default under
XYZ Tiles in the QGIS browser)? In the case of the latter, it's stored and
served by a tile server (in this case,
https://tile.openstreetmap.org/{z}/{x}/{y}.png) and as far as I know you
can't save XYZ tile layers as raster layers.
I don't use PowerBI but if it supports loading tiled maps, OGC services
(WMS) via Leaflet or Mapbox, you should be able to add/load the OSM basemap
layer by using its URL (https://tile.openstreetmap.org/{z}/{x}/{y}.png). As
far as I can tell, this option is available in similar BI platforms like
Tableau.
I hope this helps.
All the best,
Ben Hur
*Ben Hur S. Pintor | BNHR <https://bnhr.xyz>*
bnhr.xyz
hi at bnhr.xyz
*BNHR*
openness. data. geospatial.
On Thu, Aug 12, 2021 at 9:40 PM Kris Lagocki <kris.lagocki at gmail.com> wrote:
> My issue seems to be with the raster layer, can't seem to figure out how
> to have it export together with the vector layer.
> On Thu, Aug 12, 2021 at 5:27 AM Richard McDonnell <
> richard.mcdonnell at opw.ie> wrote:
>> Hi,
>> There is a TopoJSON Writer Plugin available for QGIS, you might give that
>> a try. It should write the vector dataset out as TopoKSON for you.
>> Regards,
>> Richard
>> Richard McDonnell MSc GIS, FME Certified Professional
>> *FRM Data Management*
>> Oifig na nOibreacha Poiblí
>> Office of Public Works
>> Sráid Jonathan Swift, Baile Átha Troim, Co na Mí, C15 NX36
>> Jonathan Swift Street, Trim, Co Meath, C15 NX36
>> M +353 87 688 5964 T +353 46 942 2409
>> https://gov.ie/opw
>> To send me files larger than 30MB, please use the link below
>> https://filetransfer.opw.ie/filedrop/richard.mcdonnell@opw.ie
>> Email Disclaimer:
>> https://www.gov.ie/en/organisation-information/439daf-email-disclaimer/
>> *From:* Qgis-user <qgis-user-bounces at lists.osgeo.org> *On Behalf Of *Kris
>> Lagocki
>> *Sent:* 11 August 2021 14:32
>> *To:* qgis-user at lists.osgeo.org
>> *Subject:* [Qgis-user] How can I export Vector & Raster layers together
>> Hi - I created a shape file using QGIS with a US Postal Code shape file
>> that I found on the Census website and joined it with a data file listing
>> the Postal Codes and which Sales Territory they belong to. I added in a
>> raster layer OpenStreetMap. I'd like to export both layers together and
>> import them into mapshaper so that I can export as Topojson. It has to be
>> in this format to use within Power BI. Has anyone accomplished this? Any
>> help is appreciated. Thanks.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210813/4da27d40/attachment-0001.html>
